and talk about things I did wrong
I also had a brain fart
Hi Simon,Looking at your base plates it would appear that bearings are not quite right as when looking at the drawing for the Launch engine the base plate is shown as level with the ouside bearing faces.The drawing dimension over the base plate is 3" and if you take the bearing centres from the drawing at 1.25", multiply x 2 =2.5", + 2 x .25" for the bearing thickness brings the total to 3" .Is your base plate greater than 3" not that it really matters it just doesn't look correct and the eccentrics are well clear of the base plate anyway.
Simon , nice start on the Stuart's , I would like to see a better picture of your new vise .Jeff
Quote from: K.B.C on March 07, 2016, 12:09:10 PMHi Simon,Looking at your base plates it would appear that bearings are not quite right as when looking at the drawing for the Launch engine the base plate is shown as level with the ouside bearing faces.The drawing dimension over the base plate is 3" and if you take the bearing centres from the drawing at 1.25", multiply x 2 =2.5", + 2 x .25" for the bearing thickness brings the total to 3" .Is your base plate greater than 3" not that it really matters it just doesn't look correct and the eccentrics are well clear of the base plate anyway.George, I think the bearings are to size, but there's overhang of the base on each end. I had to deal with it when boring (in an up-coming post). I think I should probably just machine down the base to size, and re-create the draft angle on the ends, leaving a boss to create the overall 3" width.Simon
The compound from Stuarts that I am building are using very recent casting set purchased late late year. See photo. You will notice that my kit of castings provides a different crankshaft to that of yours. Mine is of cast steel. Those nice people at Stuarts now incorporate square bosses at either end that allow for the drilling of centres to facilitate turning the main shaft and the two crank pins (90 deg. apart) between centres thus avoiding need to make and fit separate clamp-on 'throw' pieces. It was straight forward operation mill the bosses square to form a datum and mark the centres using a surface plate & height gauge. I will take photos and post them.
