Author Topic: 20 cc Horizontal 2 Stroke Diesel  (Read 85391 times)
Re: 20 cc Horizontal 2 Stroke Diesel
« Reply #360 on: August 01, 2021, 09:59:48 PM »
Great that you got it running again  :ThumbsUp:
Next step as you say is to make it run on only the injector - I hope that you will succeed in this too  :cheers:
Offline Minh Thanh
« Reply #361 on: August 09, 2021, 02:28:54 AM »
Hi Roger !
Can you sketch by hand with your injectors?
your injectors look very neat
 Thanks !
« Reply #362 on: August 09, 2021, 03:39:25 PM »
Hello Thanh,
Have you found my thread on fuel injection:
https://www.modelenginemaker.com/index.php/topic,4906.315.html
I will post an upto date injector drawing later
Offline Minh Thanh
« Reply #363 on: August 09, 2021, 05:56:55 PM »
Hi Roger !
I've seen
I like the way you use the injectors for your engine, I will try it with my engine
about injectors, just sketching on paper is ok
My injector picture, i'm not sure if it's the injector  ;D ;D
« Last Edit: August 09, 2021, 06:02:18 PM by Minh Thanh »
« Reply #364 on: November 07, 2021, 05:38:27 PM »
Following the results with the other injection systems I decided to lap the delivery valve on the diesel and have another try. The initial priming was much easier and the results with the 10° nozzle were encouraging.
<a href="https://www.youtube.com/watch?v=1OP6LxPb2uU" target="_blank">http://www.youtube.com/watch?v=1OP6LxPb2uU</a>
The 15° nozzle resulted in a runaway.
<a href="https://www.youtube.com/watch?v=INE2-hJ5g_A" target="_blank">http://www.youtube.com/watch?v=INE2-hJ5g_A</a>
After this it wouldn't inject or start again  ::)  :headscratch: I suspect that the injection pump plunger has overshot and jammed  :thinking:
I am currently working on a slightly smaller helix type pump which should reduce the inertia of the pump components. I am also thinking about converting this engine to a four stroke for some trials. It is much easier to separate the various influences.
« Reply #365 on: November 07, 2021, 10:02:01 PM »
Great to see that you haven't given up on the diesel  :ThumbsUp:
« Reply #366 on: November 08, 2021, 08:07:36 PM »
I'm still working on this  :thinking:  :headscratch: I am not sure if my original plan to start with a 2 stroke was the best  ::) so I am studying how easy it would be to convert to a four stroke and what sort of combustion chamber I would use. I am definitely getting 'diesel' combustion but if the atomisation is not good I think it is running on piston blow by  :toilet_claw:
