Per, thank you for your comprehensive reply
I took the head off and made a few measurements. The port timing was based on a recommendation from ETW in one of his books.
Transfer 110°
Exhaust 130°
I then used to design programme on the MEN website to come up with port heights.
Transfer 107° 91.5mm from crankshaft
Exhaust 130° 94.5mm from crankshaft
The engine is 25mm bore, 40mm stroke. The conrod is 80mm between centers and the piston crown is 25 mm above the gudgeon pin center.
First I blew down the inlet and exhaust noting the point where the port opened. This gave the following angles.
Exhaust 126°
Transfer 108°
So Blowdown 9°
Next I measured the port positions from the head joint face and calculated the positions based on 125mm from the crankshaft centerline to the head face.
Exhaust 31.5 from head face = 93.5 from crankshaft
Transfer 33.2 from head face = 91.8 from crankshaft
Putting these numbers back into the MEN program gave
Exhaust 123°
Transfer 110°
So Blowdown 6.5°
I think that the transfer port is ok but I may need to move the top of the exhaust port up by around 1mm
The ports are in three 25° segments as I am using unpinned piston rings. The width of each segment is about 5.4mm so the total port width is 16.2mm which is around 65% of the piston diameter. Breaking the port into 3 will reduce it's efficiency. The ports are rectangular with radiused corners.
The exhaust port height with the piston at BDC is 8.5mm which gives a total area of 137 mm2. The exhaust pipe bore is 8mm giving an area of about 50mm2. This as you said may also be a problem
I've got lots to learn about 2 strokes
