Supporting > Engine Ancillaries
Flanged pipework
tel:
6 bolts? You are a real glutton for punishment Simon - 4 is plenty to do the job and look OK and makes for far less fiddling.
steamer:
Simon,
The other bit to keep in mind with a screwed connection is getting the bolt holes to line up. You may want to consider a slip in soldered connection to the flange so that you can position the flange rotationally to align the bolt holes
The tubing will twist a bit once silver soldered as it is locally annealed once brought up to red heat.
smfr:
I chose six as a compromise. Peter Tarn's model (which is a constant inspiration to me) has 8 on the steam inlet pipes!
Some good tips here, folks, thanks!
Simon
Jasonb:
4 or 8 are the normal configuration that way any valves or fittings can be mounted vertically or horizontally. Full size flanges to the BS hole patterns are made that way with 12 holes on flanges for pipes over 12" dia.
Dan Rowe:
Simon,
6 bolt flanges are not really very common. I have made a bunch of gaskets like the ones John posted a sketch of and they work fine full scale.
Here is a link to pipe and flange sizes for several pressure ratings.
http://www.engineeringtoolbox.com/flanges-bolts-dimensions-d_464.html
Dan
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
