Ah, a diesel as well Jason - very nice
How do they compare, prop for prop, running wise?
Re the running, diesels will always increase in revs as the needle is closed finally breaking into intermittent (high) revving before cutting out. Glows on the other hand tend to die off after they have peaked on the needle setting as the needle is closed further. This can be a bit confusing as it can sound as if it's running rich - further closure sees the engine just fading to a stop.
Glows can also take a fairly large intake hole diameter relative to diesels so it may be slightly restricted if a tad on the small side. If you've made it the same size as the diesel it could probably be opened quite a bit more
That's a nice pair of engines though, you've made a lovely job of them - I'd be well pleased if they were mine. BTW I liked the way you approached the 'D' hole in the prop driver - nice
Now, before I get too many ideas and get carried away it's back to the plastic for just a wee bit longer
Regards - Ramon
