Supporting > Vehicles & Models
Burrell Single Crank Compound Traction Engines - 4" Scale
<< < (54/54)
Kim:
Wow, Andrew!  That is a LOT of work covered in one short post!
I think I see where the cross-sectioned part fits in, but the picture just before it - with the hole and the slot?  I'm not sure I see where that fits in and what it does.
Maybe if I let it settle for a while I'll follow it all better with a second reading.
Certainly is pretty work!
jadge:
I'll try to clarify where the parts fit. The sectioned body is simply the valve body, as shown top left in the parts picture, minus the flange and outlet . A sectioned view of the CAD model may help:
The problem with the sectioned body was that the 3/16" hole on the left wasn't lined up with the rest of the body, so the valve rod jammed. Here's a picture of the CAD model of the valve rod, which should explain where the hole and slot are placed:
In the parts picture the features are on the small end of the valve rod, bottom centre, just above the '7' on the rule. The small end diameter is 1/8". I'm not sure what function they provide, but they are clearly on the full size drawings, so I copied them.
Andrew
Kim:
Thanks for the additional explanation, Andrew,
scc:
Nice to see you are still at it :ThumbsUp:  Good work Andrew.    Terry
Navigation
[0] Message Index
[*] Previous page
Go to full version
