Author Topic: Low noise Two stroke?  (Read 15410 times)
Offline Niels Abildgaard
Re: Low noise Two stroke?
« Reply #30 on: November 20, 2015, 07:39:31 PM »
The Crecy was not low noise and the crankcase oil stayed golden.
This means that all piston and sleevevalve lubricant took the easy way out.
Some pollution
Offline BillTodd
    • Bill's website
« Reply #31 on: November 21, 2015, 12:59:04 PM »
Some pollution
All true Neils, but then the crecy was for military use and they just didn't care   :shrug:
Just thinking , given that you are trying to design a relatively low performance, quiet and clean two stroke (i.e. something ideal for portable generators etc.).  How about a stepped piston (twin) design, so you can separate the crankcase oil ?
Your poppet valve and cam might need some pretty good lubrication, which would be potentially smokey if in a petroil mix.
« Reply #32 on: July 24, 2022, 01:42:25 PM »
Please find the papers from a two stroke lovers get together 2020
https://drive.google.com/drive/folders/1YNYWcnGSqsfYqu_EV1XM_g0HQ9pOxbmv
« Reply #33 on: June 19, 2023, 04:24:21 PM »
Until some prior art can be found I feel very proud as spiritual father of this:
https://www.fvt.at/ka/en/references/layout-and-design-of-an-innovative-range-extender-engine.html
My first written describtion is this I seem to remember
https://www.homemodelenginemachinist.com/threads/sidevalve-single.23909/#post-258381
If You know of some prior art please let me know as roof/ceeling here in house is getting uncomfortably low.
« Last Edit: June 19, 2023, 04:31:29 PM by Niels Abildgaard »
« Reply #34 on: June 29, 2023, 07:34:14 PM »
The austrians from the above link are working to dominate future EV car range extenders.
They have claimed more than once that crankcase charging will not allow a three-way catalyst so they do it the Detroit diesel way.
Is it true?
By crankcase scavenging with air only and total loss lubrication about 1% of fuel amount it hard to imagine that catalyst cannot burn that?
Kirchberger Graz
« Last Edit: June 30, 2023, 08:36:46 AM by Niels Abildgaard »
« Reply #35 on: June 29, 2023, 09:15:20 PM »
Hi Niels
I might be reading this wrong - but beside a kind of Fuel / Range Extender - nothing much has come from all these studies, that will see us having a Two-Stroke in our next wheehicle ....
I have ambivalent relationship to Two-Strokes, as I loved to ride them in my youth, but also tired of all the extra maintenance / lower reliability, compared to Four-Strokes ....
Mvh   Per          :cheers:
Offline AlexS
« Reply #36 on: July 11, 2023, 10:58:17 AM »
Interesting documents you shared.
Ah if used as range extender for fixed rpm and load it might work out. And as UNIMORE showed a separated oiling system. And ad Kirchberger showed a Uniflow exhaust valve setup.
Only maybe have to test it with trying to use hydrogen or a blend for combustion this should give a weight/power output. I know you can generate electricity form hydrogen fuel cells. But there you have to condition the PEM cells and require (as far as I know) platina or similar resources (availability?).
So as second option?
« Reply #37 on: July 11, 2023, 01:14:50 PM »
I think it is the real solution and my question is if the charge free crankcase is nessecary for going threeway catalysing.
The main road is to keep charge low(MEP =6bar), and uniflow.In that case a V2 with common crankcase
will be much simpler and lower mass.
Click on the picture and open in another window
It shows a comparison of a crankcase scavenged 100/150 mm bore/stroke cylinder with a blower fed doing same work
« Last Edit: August 08, 2023, 04:54:03 PM by Niels Abildgaard »
