Author Topic: Another Hodgson Radial 9  (Read 44265 times)
Offline Camm-1
  • Sweden
Re: Another Hodgson Radial 9
« Reply #30 on: December 27, 2014, 07:02:56 PM »
Thank you Bill☺
Yes this is the parts that make it seems something on a few weeks.
It is a lot left.
Ove
« Reply #31 on: December 27, 2014, 09:03:37 PM »
Hi Over, just catching up on your thread and seeing some beautiful work. Those cylinders look great.
Offline petertha
« Reply #32 on: December 27, 2014, 09:25:06 PM »
Some more progress on the cylinders. Got my tool to cut well but grind it a bit to small so it been 15 grooves instead of 14 :)
Nice build! A few questions:
- did you use the (I think specified?) 12L14 leaded steel for cylinders, or different metal?
- what did you end up using for a grooving tool for fins?
- are these cylinders already lapped/honed to final dimension, or that stage is coming later?
Offline Camm-1
  • Sweden
« Reply #33 on: December 27, 2014, 09:48:48 PM »
Hi peertha.
The steelspec in sweden is not the same at all I think.
I bought a bar that called comprimated axel here.
It turns very nice but  think thats ok to use most of steels.
In my inline six I made the liners of some steelpipe and it runs greater more it runs.
For finning I first grind off a ss 10mm square turning steel to about 0.59mm
I broked it off when I had 2more cyliders to fin.
When I grind off a ss partingblade instead on one side, it goes faster to grind off
Because it it thinner and I am lazy.
I turned all liners in the last pass with the same setup in the lathe to about 0.997-0.998 final lapping to 1" is remaining.
Ove
« Last Edit: December 28, 2014, 07:46:09 AM by Camm-1 »
Offline Camm-1
  • Sweden
« Reply #34 on: January 06, 2015, 05:22:48 PM »
Some more have been done.
Ģot the cylinders threaded and start fighting with the heads.
1 and a halv day just to prepare the blocks and rough mill the downends.
« Reply #35 on: January 06, 2015, 07:00:22 PM »
That's a lot of parts to make  ::) Looking good  :ThumbsUp:  :ThumbsUp:
« Reply #36 on: January 06, 2015, 07:05:55 PM »
Hi Ove, you are doing a great job over there. Still following along.
Offline 90LX_Notch
    • YouTube Channel
« Reply #37 on: January 06, 2015, 10:20:01 PM »
Ove-
Amazing work thus far.  It would take me twenty years to make the progress that you have on this engine.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #38 on: January 07, 2015, 12:17:43 AM »
Looking good Ove!!  Amazing progress you are making too.
Offline Camm-1
  • Sweden
« Reply #39 on: January 07, 2015, 05:52:04 AM »
Thank you all that hanging on here😊
Well now all holidays are over and the build would slow down a bit.
Still have to work at least 10 years more before I can build engines all days😉
Offline Camm-1
  • Sweden
« Reply #40 on: January 14, 2015, 08:03:07 PM »
I have not been in the shop for some days but tonight I threaded 6 heads.
Offline icman
  • lincs uk
« Reply #41 on: January 15, 2015, 07:44:55 PM »
nice to see you back in the workshop ove. regards mike
Above workshop door. "abandon hope all ye that  enter here "
« Reply #42 on: January 16, 2015, 01:14:32 AM »
Progress is still progress Ove. Those look really nice.
Offline petertha
« Reply #43 on: January 16, 2015, 03:00:37 AM »
I like the dark color of your cylinders. How did you do that?
Offline Camm-1
  • Sweden
« Reply #44 on: January 16, 2015, 05:13:22 AM »
Hi boys!
Thanks Bill, Mike, Peter..
Peter, the cylinders are still just shiny it must be the light that they look dark.
I am going to try blueing them with Gunblue I bought on Ebay but thinking about a
the best way to degrease them ok before. A test on tool CH2 get flamey that I wiped off with aceton before.
Ove
