Author Topic: Another Hodgson Radial 9  (Read 44195 times)
Offline Camm-1
  • Sweden
« on: November 30, 2014, 06:21:09 PM »
After reading all treads about the Hodgson-9 I could not resist to try building one to. :Love:
I have only built to engines before ,my Hoglet and the inline 6 so maybe not the best choise of build but I need challenge  ;D
I started with the cylinders but get trouble with the finning so I put them aside for a while dont want to stuff up more than one of 11.
I went ahead with the crancase instead. Bought a pice of 7075 a bit longer then needed to take a drawbar in the end, was afraid to only
hold that big chunk in 1/2" grip.
I turned all the inside and outside in that setup like I read on another builders site.
It was a bit tricky inside but all went well and I got the right dimensions.
At last I cut it off but left 2mm that I cut off with a hacksaw.
The leftover was turned to a good fit to to have on my rotarytable later.
Cheers Ove
Online Roger B
Re: Another Hodgson Radial 9
« Reply #1 on: November 30, 2014, 06:57:50 PM »
That's a nice challenge you have set yourself and a good start  :ThumbsUp:  :ThumbsUp: I'll be following along  :popcorn:  :DrinkPint:
Online fumopuc
« Reply #2 on: November 30, 2014, 07:25:15 PM »
Hi Ove, surely I will watch every step of your build.
« Reply #3 on: November 30, 2014, 07:32:26 PM »
Wow Ove, First two cylinders then six, now 9  :o. I take it you have got the hang of making cylinders  ;)
When you have done my friend Mike has the design for a very sexy 18 cylinder radial  :popcorn:
« Reply #4 on: November 30, 2014, 08:16:35 PM »
Will surely be following this build Ove.  Keep it up.
Offline ths
« Reply #5 on: December 01, 2014, 11:32:30 AM »
I like your case for keeping everything in order, great idea. Looking forward to more. Hugh.
Offline Camm-1
  • Sweden
« Reply #6 on: December 05, 2014, 08:19:24 PM »
Tonight I milled the flats and bored the cylinderholes.
Was happy to have a 27mm drill the finish bore are 28.65 mm.
Also braked off the edges of the flat edges.
« Reply #7 on: December 06, 2014, 12:00:50 AM »
Some nice progress Ove!!  Still following along with much interest.
Offline Camm-1
  • Sweden
« Reply #8 on: December 06, 2014, 08:33:03 AM »
Thanks Bill ,and all others!
It is a lot of cranking and counting on this crankcase. I hope a manage to put the rest of the holes in right places.
This is the only part I realy dont want to do one more. This aluchunk cost like gold :)
Ove
Offline Camm-1
  • Sweden
« Reply #9 on: December 06, 2014, 01:14:33 PM »
Spotdrilled all the cylinder holes today. I instaĺled a sino dro earier this year and had to read how to make a boltcircle and at last I get the corect start and stopangle. Thats a great thing.
Ove
Online Roger B
« Reply #10 on: December 06, 2014, 06:40:13 PM »
That's looking good  :ThumbsUp:  :ThumbsUp: , but as you say there are a lot of holes to drill and tap  ::)
Offline Ramon Wilson
  • Suffolk in the UK
« Reply #11 on: December 06, 2014, 08:02:13 PM »
Very nice work Ove  :ThumbsUp:
Good luck with the build - there's a lot of enjoyable machining ahead of you. I began a rotary engine in 1992 so hope you have far more resolve that I have had to date to see it through  ;)
I shall watch with interest in your progress.
Regards - Ramon
« Reply #12 on: December 06, 2014, 11:40:55 PM »
Looks like 72 holes to drill and tap there Ove. I hope it all goes as smoothly as it has so far.
Offline johnl
« Reply #13 on: December 06, 2014, 11:51:55 PM »
IIRC there were just under 140 tapped holes on my H9 crankcase. John
Offline 1dbweldor
« Reply #14 on: December 08, 2014, 05:17:47 AM »
Looks like your off to a good start. The heads are a machining marathon. I keep telling myself "You're not in any hurry, slow down and enjoy".
