Drill a pair of holes parallel to the "V" and put pins in that are pressed into the milling straps. That way you can grip is far lower! That set up looks scary to me!Dave
Quote from: steamer on October 28, 2014, 01:03:30 PMDrill a pair of holes parallel to the "V" and put pins in that are pressed into the milling straps. That way you can grip is far lower! That set up looks scary to me!DaveThere need to be two M5 clearance holes in one end. I could put them in both ends and clamp as you suggest. That's the advantage of the forum you post a problem and get ideas back
