Author Topic: Miniature Ford 300 inline six (video)  (Read 12992 times)
« on: May 09, 2014, 06:57:11 PM »
Gentlemen,
The engine is running. Having been away for almost 5 weeks I was in a rush to get it running for the NAMES show but that didn't happen. My apologies to those fellows that came to the show to see it running. This is the second running. I fired it up earlier in the week but had a few adjustment and modifications to make.
It seems like the air bleed hole in the carb needs to be a little bigger because it takes too much adjustment on the main needle to go from idle to high speed.
So far everything seems to be working well. It looks like it will need a different seal in the timing cover because it leaks a little.
Here's the link to the Youtube video.
<a href="https://www.youtube.com/watch?v=tdrEHY3uqqs" target="_blank">http://www.youtube.com/watch?v=tdrEHY3uqqs</a>
Re: Miniature Ford 300 inline six (video)
« Reply #1 on: May 09, 2014, 07:22:23 PM »
You have outdone yourself George!!!  That is one beautiful little engine and sounds as good as it looks. Congratulations on yet another project that most of us can only aspire to!!
Online fumopuc
« Reply #2 on: May 09, 2014, 07:53:10 PM »
Hi George, that is brillant.
« Reply #3 on: May 09, 2014, 07:56:21 PM »
Wow - what a great runner and it's beautiful too :praise2:  :praise2:  :praise2:
One tiny detail - it appears that you should consider copper washers under the sparkplugs like on the full size engines - it looks like "air bubbles" around the leftmost plug.
It sounds like you're very close to perfection on the ignition timing and with the carburettor - it idles well and pickup revs quickly -  :NotWorthy:  :praise2:  :NotWorthy:
Offline dnalot
« Reply #4 on: May 09, 2014, 07:57:55 PM »
That’s outstanding; I'm so envious of your talent.  How long have you been working on this project?
Mark T
Some times it's better to keep quiet and be thought a fool than to speak and remove all doubt.
Offline tangler
  • Christchurch, UK
« Reply #5 on: May 09, 2014, 08:32:01 PM »
George,
That's truly wonderful.  I'm intrigued that what appears to be a simple R/C plane type carb is so successful on a complex engine.
Very nicely done  :praise2:
Rod
Offline ths
« Reply #6 on: May 09, 2014, 08:37:41 PM »
Congratulations George, outstanding, looks and sounds great. Hugh.
« Reply #7 on: May 09, 2014, 09:05:15 PM »
What a wonderful model engine George, and superb detailing.
« Reply #8 on: May 09, 2014, 09:18:49 PM »
Damn George.....That's beautiful!
Well done!.......
 :praise2: :praise2: :praise2: :praise2:
« Reply #9 on: May 09, 2014, 09:27:54 PM »
As usual, George...
Wow!  Just wow!
Offline Mosey
  • Rosemont, New Jersey, USA
« Reply #10 on: May 09, 2014, 09:44:49 PM »
George, It is worth every minute you put into it and is a stunningly good engine! Thanks for showing it to us.
Mosey   :praise2:
« Reply #11 on: May 09, 2014, 09:46:16 PM »
Thanks fellows for the comments,
Rod, over the years I have built and tried almost every type of carburetor and the ones that seem to work best are the simple air bleed type. It takes a little experimentation with the air bleed size for each particular engine but once that's sorted out they run very well.
I noticed the front plug bubbling a little in the video. It's funny how when photographing something all the warts pop out. Presently I don't have any washers on the plugs but I'm going to make some annealed copper washers. That should do the trick.
Offline crankshafter
  • Molde, Norway
« Reply #12 on: May 09, 2014, 09:55:18 PM »
Hi George.
Have been waiting for this moment of thruth. What a beuty, what a sound  and good looking, just incredibel.
What's next?
Best Regards
CS.
"I cut it twice, and it's still to short"!!??">#%
« Reply #13 on: May 09, 2014, 10:06:40 PM »
Incredible work George. You are a true master.---Brian
Offline sshire
    • LS Editions
« Reply #14 on: May 09, 2014, 10:12:49 PM »
As usual, I look at your engine with wonder and amazement. Absolutely magnificent!
What else can you say?
Best,
Stan
