Then I tried something totally new to me, a wooden boat.Got keel, ribs & transom in but was defeated by the planking which twists, curves & changes shape all at the same time. At this point I don't think it can't be done with SW. Be warned: if you think it can be, I'm going to send you my files & make you prove it.
Bob, I took a look at the pdf's. They ended up making a shell like a fiberglass hull. That's too easy. I was trying to model each plank as worked it's way down the ribs & formed the hull shape. This is one of those things that are probably easier to do with a real board on a real boat than in a computer.
