Help! > Specific Engine Help
Liney RV-1 valve port size
<< < (2/3) > >>
smfr:
I just now looked at pictures of the Liney RV-1 and realize that it doesn't have slide valves, so take my advice with a large pinch of salt!
Does it have a standard wobbler-type valve arrangement? If so, I think doubling the hole size should keep the timing the same, right?
Simon
sshire:
Simon
Salt taken.
It's a rotary valve. The cylinders are located at each end with a longitudinal air passage and inlet and exhaust passages intersecting it.
b.lindsey:
Stan, Liney also recommends drilling the port holes in place at the time of assembly. It can be done otherwise as they also point out, but I followed their advice and the timing worked perfectly. This will be a sizeable little engine ar 2X scale!! Keep us posted as you progress please.
sshire:
I've studied the plans for the last month and have certain areas highlighted. The valve drilling in place is one. As you've found out, it's a good idea re: valve timing.
This should be an adventure.
A big tube appeared on the front porch yesterday from Online Metals! I could have saved time by just ordering 10 pounds of chips from them. I'm going to tram the BP, give the one- shot oiler a push,spread some way oil on the lathe and begin.
Also going to email Doug at Liney to get his thoughts on the 2X RV-1. I can't be the first one to try this.
b.lindsey:
Stan, what did you mean re: Online Metals? Were the items packed badly? damaged in shipment?  Could be something other members may want to know.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
