Author Topic: 1/4 32 spark plug tap drill size ?  (Read 5756 times)
Offline V 45
  • central PA...USA
« on: September 18, 2013, 04:45:06 PM »
Another question !! Sorry for asking soo many...but I looked up the drill bit size for 1/4 32 tap. I found either 7/32" or a #2 bit. Which is perferred ?
  Thanx again,
Re: 1/4 32 spark plug tap drill size ?
« Reply #1 on: September 18, 2013, 05:10:59 PM »
Hey Dave,
Well, google is your friend.    I found that 7/32 is preferred  (.2188) while #2 (.221) is an alternate.
I would use the 7/32 for general use, and .221 for really tough to tap applications like stainless steel ect.
Offline gmac
  • British Columbia Canada
« Reply #2 on: September 18, 2013, 05:24:11 PM »
Dave;
From Little Machine Shop.....inch and metric
http://littlemachineshop.com/Reference/TapDrillSizes.pdf
Enjoying your build, you've got me chopping up material for a build again - thanks!
Cheers Garry
« Reply #3 on: September 18, 2013, 05:25:51 PM »
100% engagement = 5.4mm
80% engagement = 5.6mm
What % engagement you choose will depend on the material and the purpose.
« Reply #4 on: September 18, 2013, 05:39:17 PM »
That jives  Jo....  0.2188 ...OK  .219 is about 75% engagement...which is considered nominal....at least on this side of the pond.
« Reply #5 on: September 18, 2013, 05:42:53 PM »
Without considering depth of thread...
TD = 0.25 - 1/32 = 7/32   (77% DOT)
For N % DOT...
TD = 0.25 - 0.013*N/32
N = 50 is a good choice for stainless in which case the above yields:
TD = 0.2296
A #1 (curse these stupid American designations) is 0.2280 which corresponds to 54 % DOT.  A 5.8 mm drill (0.2283) is slightly closer and yields a 53% DOT but that is all turd polishing - use the formulae as guides and pick your closest drill.  Keep the DOT below 75 % for tougher and intractable materials, e.g. bronzes, nickel silver, stainless.
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #6 on: September 18, 2013, 06:33:23 PM »
I use an android app for calculations of tap drill size. There are several free ones I like Tap Drill Tool the best as it works for most of the threads I have in the shop. It works for both cutting taps and form taps.
Dan
ShaylocoDan
« Reply #7 on: September 18, 2013, 06:42:08 PM »
When I've used 1/4x32 UNEF for glow plugs I had drilled 5.5mm.
As its likely to be something that is in & out quite a bit and into an aluminium head you want a decent depth of thread
Offline V 45
  • central PA...USA
« Reply #8 on: September 18, 2013, 07:12:37 PM »
Thank you everyone !! As Jason stated it will be going into aluminum and the thread depth will only be about .300" or a little less.
I don't own any metric drill bits !!! I do have fraction, letter, and wire bits. With that said is 7/32" the way to go? Or get a 5.5 mm bit? I could most likely borrow one to have the deeper thread.
  Thank you again,
« Reply #9 on: September 18, 2013, 07:27:55 PM »
7/32" should do you fine, I doubt the extra 0.05mm ( 0.002") will make a lot of difference. If you drill 3/16" followed by the 7/32" it should eliminate any risk of it cutting oversize.
« Last Edit: September 18, 2013, 07:49:33 PM by Jasonb »
« Reply #10 on: September 18, 2013, 07:47:44 PM »
Jason,
I think you mean....drill for 3/16 and then 7/32".....right?
« Reply #11 on: September 18, 2013, 07:50:03 PM »
Thanks Dave, I've altered it to 3/16"
« Reply #12 on: September 19, 2013, 12:43:33 AM »
We all know a drilled hole isn't all that round. So, should you ream before you tap or will the tap do that for you? Or does it make a big rat's butt?
Whiskey
« Reply #13 on: September 19, 2013, 12:50:09 AM »
I have never reamed a tap drill hole....but having said that....I would bet someone has to get a very good fit.
Then again...if the nut was that important...I've always single pointed it in the lathe anyway....after boring to size.
« Reply #14 on: September 19, 2013, 01:34:57 AM »
I never have either. Just one of those things that make you wonder. I bet it would tap a little easier.
Whiskey
