Author Topic: Building a 7" rotary table  (Read 60676 times)
Offline NickG
Re: Building a 7" rotary table
« Reply #165 on: June 02, 2014, 08:19:32 PM »
That is superb Rich! Yeah 6mm makes most sense then.
Offline Firebird
  • East Midlands UK
« Reply #166 on: June 08, 2014, 01:53:52 PM »
Hi
Thanks Nick.
I have ordered a T slot cutter, from china, so I have to wait for that to arrive. I don't know what the quality will be like but at les than £6.00 including the postage its worth a go.
I have had to make a little spacer to use when the rotary table is mounted vertically. The edge of the table just catches, it was ok until I fly cut the sides.
A bit of 4mm ally, a bit of 3/16" X 1/2" X 3" steel and a couple of 5mm countersunk socket head screws.
This is the table with the clamps fitted
I have made a little gadget to centre the table in the mill. A quick turning job. Turn down accurately to 1/2" to fit the hole in the centre of the table.
Part off and hold in a 1/2" collet. Face and centre drill.
Drop it into the table
Bring down a centre point and square with a set square
Clamp the table down, lock the X and Y tables and zero the dials, easy
Rich
« Last Edit: June 08, 2014, 01:59:50 PM by Firebird »
« Reply #167 on: June 08, 2014, 04:41:30 PM »
Hi Rich,
I've been quietly following along with your RT build.  This is a nice piece of equipment you've built here! You should feel really good about it!  Congratulations on some great work!
Do you have anything else to go besides the T-slots?
Offline Firebird
  • East Midlands UK
« Reply #168 on: June 08, 2014, 04:47:16 PM »
Hi Kim
Thanks  :ThumbsUp:
No that will be about it for the table. There are a couple of bits of tooling I have in mind one being an adapter that takes the Myford screw on chucks but they will be made as and when I need them.
Rich
Offline Firebird
  • East Midlands UK
« Reply #169 on: June 13, 2014, 07:57:19 PM »
Hi
The T slot cutter arrived today
I have never used one before so any tips would be welcome
Rich
« Reply #170 on: June 13, 2014, 08:00:38 PM »
Slow and steady, get (vacuum) the chips out, you should not have any problems, it is not a difficult job  ;)
Offline Firebird
  • East Midlands UK
« Reply #171 on: June 14, 2014, 01:16:16 PM »
Hi
Thanks Jo.
Do you mean a slow cutter speed ?
Rich
Offline Stuart
  • Tilchestune UK
« Reply #172 on: June 14, 2014, 01:28:51 PM »
Rich
If the. Table is CI. Then do not let the cutter rub it's the same for steel
As Jo said think how fast you would run a cutter of the same OD
I would run a normal slot mill in first to full depth then follow up with the the tee slot cutter but run it a smidge up from the bottom of the slot , it should not rub on the end , it's the same with a dovetail cutter do not cut on the end and side at the same time or tears will be shed
I fully endorse Jo use of the vacuum to keep the slot clean
If it gets blunt you can with care touch them up on a grinding wheel
Offline Firebird
  • East Midlands UK
« Reply #173 on: June 14, 2014, 01:51:32 PM »
Hi
Thanks Stuart. Its fathers day tomorrow and when asked by my 3 lovely daughters what I would like to do I said spend the whole day in my shed alone. Well if thats what you want they said. Oh and a chinese take away for the evening meal would be nice. And of course  :DrinkPint: :DrinkPint: :DrinkPint:
So hopefully tomorrow I wil cut the T slots
ricc
« Reply #174 on: June 14, 2014, 05:56:10 PM »
Sounds like you have tomorrow made for you  :ThumbsUp: (I also like Chinese, nice change from curry  8) but its Saturday so its Sirlion  ;D)
I agree with Stuart (a couple of cuts to) take the centre to full depth with a slot mill first, don't worry if it goes slightly deep on one or another. Most tables you buy are not perfect when you look at the slots, you don't even have to get the tops of the slots spot on  ;)
« Reply #175 on: June 14, 2014, 09:33:52 PM »
Hi Rich, I agree with Jo and would add to slow your spindle speed also to where the cutter is warm to the touch. It will cut the full slots and stay the same temperature when you have the right speed.
Regards Don
Offline Firebird
  • East Midlands UK
« Reply #176 on: June 15, 2014, 04:50:09 PM »
Hi
Well I'm pleased to say that the T slot cutting went well.
One little job to do first. I forgot to scribe in some pointers for the hand wheel and table so I got my mate Julian to print me a couple. He has aneat little lable printing gadget that prints into a plastic type ribbon
With the table at zero and the handwheel at zero I cut the first slot with a 8mm cutter. This is a solid carbide cutter that I picked up at a show and cuts beautifully. You can see on the DRO I have cut to a depth of 12mm
With all 4 slots cut it was in with the T slot cutter, nice and steady.
I have drilled and tapped the table 4mm
Turned and bored a sleeve that fits the central locating hole
Which takes the myford threaded adapter
With a myford chuck screwed on
Rich
« Reply #177 on: June 15, 2014, 06:11:04 PM »
 :whoohoo:
So what are you going to make on it  :naughty:
Offline NickG
« Reply #178 on: June 15, 2014, 07:57:45 PM »
Brilliant Rich, looks v professional.
Offline Firebird
  • East Midlands UK
« Reply #179 on: June 15, 2014, 08:06:04 PM »
Hi
Thanks Jo and Nick
Hopefully this current bout of tool making is over and I can get back onto my portable engine.
I would like to thank every body that has helped with this build, new skills had to be learned and I couldn't have done it without you.  :ThumbsUp:
Rich
