Next part to be made is the cylinder and its column, this is the full size one.
I had a gunmetal casting for this but it turned to be unsuitable for various reasons so I elected to fabricate it from two machined parts. My initial thoughts were to use gunmetal or phosphor bronze and then silver solder them together.
However in reality this engine is intended to be run on compressed air and will probably never need to run on steam, so I have decided to make the parts from cast iron and bond them together with loctite 601 instead, this has the advantage that areas of bare metal will be the correct colour as per the prototype.
Most of the operations are fairly straight forward turning and milling and the photo's should be fairly self explanatory.
The basic shape of the column was turned and bored for the crosshead.
A mandrel was then made and loctited into this bore so the part could be reversed and held in a collet for machining the cylinder bore and sleeve diameter for the steam chest to fit over.
This mandrel was also used to hold the part on the jig borer for milling the 1mm wide slots for the valve ports to transmit steam/air to either end of the cylinder.
The four mounting holes were added using the PCD function on the jig borer DRO, I had to make an extended centre drill to reach the flange.
For reasons which will become apparent I had other things on my mind and completely forgot to take photo's at this stage, so you will have to use a bit of imagination.
Moving onto the bigger milling machine I mounted the part in the dividing head to remove the material from either side of the column. I had designed this with an angle of 50° either side of the centreline, so I had to work out how many turns and holes were needed to achieve this.
I counted 80 teeth on the wormwheel, so ended up with the calculation (50/360) x 80 = 11.11 turns of the dividing head handle, which equals 11 turns and 2 holes on the 18 hole circle.
Being cautious and not wanting to scrap this part I decided to test my maths and see if it looked right in practice prior to cutting any metal. A good job I did because it moved way too far, in fact it seemed to go twice as far as it should
I checked my maths again and got the same result which was very puzzling, it was a little while before the penny dropped and I discovered the dividing head has a two start worm and is in fact 40:1 ration and not the 80 that I had counted earlier
So back to the maths and we now have (50/360) x 40 = 5.5555, or 5 turns and 10 holes on the 18 hole circle. Back to the machine to test the maths again and all is now OK. At this point the day is over and I went indoors
So the following day I resume work and start making cuts, the first cut went perfectly, so I indexed to the next position and proceeded with the cut, something did not look just right and I started to doubt that I had counted correctly with the dividing.
The third cut seemed to go a lot better, but the last cut was an absolute disaster, there was a massive gouge where too much meat had been removed. It was now clear that this part was going in the scrap bin
You are probably wondering why this happened as I was. Well it was a case of me thinking I must have tightened the dividing head collet the night before, but not actually doing it.
So the part was only finger tight and was revolving in the collet and being pulled into the cutter........What an idiot
The only option now was to start all over again and make another one but remembering to tighten the collet this time.
The last operation I did was to drill and tap the 10BA holes for the piston rod gland.
And here it is in position on the engine, all it needs now are the webs up each side making and fitting.
The steam chest part of this assembly will follow in due course.
Phil
