Hi Everyone
Here are some photos of machining the valve lifter; I machined most of it on my CNC at work and then finished it up in my shop at home. This was a milestone for me as all the timing parts are now finished and after the exhaust valve is completed and it's seat cut, it will be on to a different part of the engine.
I chose to make this part from scratch and as I have indicated before I made some modifications to change the alignment of these parts.
I just want to say if anyone is curious, there is nothing wrong with the castings or drawings; this is just something I wanted to try and as I indicated awhile back; if it didn’t work I would use the castings machine them to the print.
The valve lifter was designed in a 3d CAD program and printed on one of our rapid prototype machines to check the fit. Once satisfied the basic shape was programmed and run on the CNC.
Here the bottom side of the lifter has been roughed out with a ¼” ball end mill.
Then followed by a 1/8” and finally a 1/16” ball end mill.
Ready for the next operation, made two just in-case.
The block is flipped over and the top side is surfaced. The web pieces holding the chucking pieces on are located where the slots will be.
Standing on edge the holes are spotted and drilled.
Ready for the finishing operations.
I needed the bronze shoe so it was made before the lifter was finished. Here a piece of prop shaft (Naval Bronze) was turned and faced and set up in the mill.
The profile of the shoe is machined.
Then back in the lathe the shoe is parted off.
The first chucking piece is cut off.
The lifter is set up on a fixture plate, indicated in and clamped down.
The shoe slot is milled using the recently completed shoe to check the fit.
Back to the saw the other lug is removed.
Due to the shape this operation took some creative use of parallels to hang on to it.
Before and after; cutting the slots was kind of a tedious process mainly because I didn’t want to screw up after putting that much work into it.
The swing arm is set up and drilled for the pivot bolt.
And finally a fit check with the new parts; I’m a happy guy!
Here’s a different view.
Just for grins here is the printed part alongside its machined counterpart. The 3d printer got a workout as I was trying to get a design that I was happy with.
Thanks for checking in,
