Engines > Restoration of Model Engines
Ernst Plank Hercules
(1/1)
Hanst:
Hi, I’ve acquired a relatively well-preserved Ernst Plank Hercules steam engine. However, it has a period modification that I really don’t like. I’d like to ask for your opinion or advice on what to do with it.
The solutions I’m considering are:
Add a glass tube to the water level indicator and leave everything as a period modification.
Remove the fittings, clean it up, and replace the water level indicator in the style of Plank models (I would appreciate details of the water gauge from a Plank model—thread dimensions of the fittings, diameter of the glass tube, and a detailed photo).
Carefully remove the fittings, plug the holes, and retouch the surface.
Thank you in advance for your opinions and advice.
Hanst
internal_fire:
--- Quote from: Hanst on March 28, 2026, 04:01:42 PM ---Thank you in advance for your opinions and advice.
--- End quote ---
Are you familiar with the various collector forums?
One that I look at sometimes is Office of Steam Forum https://www.officeofsteamforum.com/
Lots of folks there with opinions on what you should do with a model like this.
Gene
Hanst:
Thank you for your response
Navigation
[0] Message Index
Go to full version
