Author Topic: Blockhead  (Read 12138 times)
Blockhead
« on: March 11, 2026, 08:08:56 PM »
My next project is underway despite having only the outline of a plan. As usual it'll be a blocky bar stock build, a variation (refinement??) of the single-acting twin cylinder finished a few days ago. This time there will be a single inlet and no external pipework to the cylinders. I'll also use a scotch yoke to save a bit of space between the cylinders.
Here's all the progress I have made this evening - facing the valve block/bearing and the arms of the frame that the cylinders will be attached to. I planned on using some thinner brass for the frame but couldn't lay my hands on any so this will have to do.
P.S. Don't bother clicking the thumbnail unless you're really bored as there is nothing worth looking at  :lolb:
Offline Sanjay F
Re: Blockhead
« Reply #1 on: March 11, 2026, 08:21:34 PM »
Is this going to called Ian after Ian Dury and the Blockheads? I instinctively clicked on the thumbnail ......... interesting!  ;)
Looking forward to another build and you seem to be assimilating parts from your various other builds and bringing them together into this one?  :popcorn: :ThumbsUp:
« Last Edit: March 11, 2026, 08:27:17 PM by Sanjay F »
Offline 55fairlane
Re: Blockhead
« Reply #2 on: March 12, 2026, 12:31:33 AM »
You said "blockhead" I thought we were see an "evo motor" from Harley Davidson
Imagination is much more important than knowledge
Re: Blockhead
« Reply #3 on: March 12, 2026, 12:59:06 AM »
My first thought were the heads of the old Rockem Sockem Robots...
Re: Blockhead
« Reply #4 on: March 12, 2026, 06:55:41 AM »
 :Lol: Sorry to disappoint you fellows, it won't have anything to do with robots or motorcycles (or hitting things with rhythm sticks).
As it'll be blocky in appearance and a follow on from Baldrick, in GB English a blockhead is a stupid person (bonehead, knucklehead).
Re: Blockhead
« Reply #5 on: March 13, 2026, 08:02:02 AM »
Not much time to get stuck in yesterday, just sawed and turned the two parts of the frame (with blue ink) down from 5/8" to 3/8" thick. I was planning on turning a spigot on the end of each of these where they enter the bearing/valve block (the bit with '19' on it) but in the middle of the night decided it would be easier to drill a hole in each and connect with a 'dowel' then solder together. That probably doesn't make much sense (!) so here's the plan which probably doesn't make things any clearer  :Jester: :Lol: :lolb:
Re: Blockhead
« Reply #6 on: March 13, 2026, 05:12:45 PM »
After a day of digging with windchill bringing the air temp down to 2-3C I could only take an hour or so in the cold workshop. Managed to get the cylinders turned down to length and the bore sorted for the crankshaft. Not very exciting again but at least the shape of the engine is appearing. It's blocky.  :Lol:
Offline Sanjay F
Re: Blockhead
« Reply #7 on: March 14, 2026, 07:41:40 AM »
That's great, I see it now - 'I love seeing a plan come together' to quote Hannibal from the A-team  ;)
Re: Blockhead
« Reply #8 on: March 14, 2026, 12:56:18 PM »
Cheers Sanjay.
This morning I drilled the long passages through the two frame pieces and the short perpendicular passages to the cylinders. The ends nearest the shaft were then opened out and matching holes drilled into the valve block to meet the shaft. I made two short dowels with an air passage, these will be soldered into the frames/valve block after I've finished drilling and plugging the other five passages through the block. Here are the parts just placed together, the dowels will disappear inside when finished.
Re: Blockhead
« Reply #9 on: March 16, 2026, 11:00:40 AM »
Given the state of my pillar drill it's always pretty tense when trying to align small holes but fortunately all went well this morning when I drilled the 1.5mm air passages in the bearing/valve block. Now I just need to plug most of those holes! If anyone is interested, the arrows on the right image shown the route air will take to the valve flats then in and out of the cylinders (blue and red arrows) before being expelled via a hole in the shaft (red arrow). It means I'll have just a single inlet on top (which is the left side in the photo) and no external pipework.
Offline Sanjay F
Re: Blockhead
« Reply #10 on: March 16, 2026, 01:59:41 PM »
Given the state of my pillar drill it's always pretty tense when trying to align small holes but fortunately all went well this morning when I drilled the 1.5mm air passages in the bearing/valve block. Now I just need to plug most of those holes! If anyone is interested, the arrows on the right image shown the route air will take to the valve flats then in and out of t :popcorn:he cylinders (blue and red arrows) before being expelled via a hole in the shaft (red arrow). It means I'll have just a single inlet on top (which is the left side in the photo) and no external pipework.
That is interesting thanks for the explaination - annotated photos are better than text for sure!  :ThumbsUp:  :popcorn:
Re: Blockhead
« Reply #11 on: March 16, 2026, 07:44:11 PM »
Making it up as I go along and finding myself going off piste with this one...
First photo, all the bits before soldering.
Second, after silver soldering - there was some slight misalignment so some vigorous sanding was needed to get things nicely flat and square, fortunately there are no critical dimensions involved. I decided the passages that needed plugging were too close the the edges and the passages themselves so small that there was every chance of bu**ering things up so I decided to make some 'cladding' instead  :lolb: This photo also shows the upper piece with the air inlet, which passes through a clearance hole and is threaded into the top of the block.
Third photo, shows one pair of holes on the side of the block which will also be covered by a small piece of brass.
Last photo, the parts in place ready for (soft) soldering tomorrow.
Re: Blockhead
« Reply #12 on: March 17, 2026, 11:00:39 AM »
Soldered the bits together, looks a bit rustic and still needs some cleaning up but it seems to have sealed things without blocking any passages.
Re: Blockhead
« Reply #13 on: March 17, 2026, 11:03:53 AM »
Another interesting design to follow along  :)  :)  :ThumbsUp:
Re: Blockhead
« Reply #14 on: March 17, 2026, 03:48:57 PM »
Cheers Roger.
I've now got the cylinders mounted, with the final bit of air passage drilled in each one. Thankfully the alignment between the two bores seems good, testing here with a long piece of silver steel.
