A Compression Ignition (CI) engine uses the Diesel Cycle, its speed and torque are controlled only by varying the amount of fuel delivered. A Petrol (methanol) Injection (PI) uses the Otto Cycle where the its speed and torque are controlled by the amount of AIR and FUEL mixture delivered through a carburettor or by injection. The air throttle and the fuel injection halves need to work in perfect harmony to deliver the correct amount of fuel in all throttle/ speed/ load conditions. A carburettor does that automatically by air flow though the venturii past the fuel jet.How are you proposing to get the air side to control the fuel side? Mike
Thank you Dave These experiments are my ‘fun’ with this hobby. ................I have purchased the drawing of Schilling’s fuel injection system and have a few more details:The fuel pump uses 11 tooth MOD 1 gears 4mm thick. This seems to have a much higher capacity than the one that Mike proposed. There is no mention of the operating pressure and no details of the relief valve spring to allow me to make an estimate.The injectors are very similar to model engine carburetor needle valves. There is a 0.6mm orifice and a 10° tapered needle with an M3 thread. He does describe the system as a carburetor without a float chamber.
Interesting Do you think the body could be turned down? To what size?For a manifold injector it could be glued into an injector body. Easier than a cylinder injector.
