No idea of the answer but am interested by what you say about the linkage and what it does; is that there to keep both cylinders synchronised with each other mechanically rather than timed 'by measurement or by eye'?
Walschaert-ISH
Hi Chris Not much for crime story "who dunnits", but love a good mechanical "what dunnit". It looks to me that the "lower left" crosshead only runs the "upper right" valve & the U.R crosshead runs L.L. valve. Starting at lower left crosshead there's a link parallel to conrod, pinned to a link with a tee shape. I assume the tee piece is the expansion link. It appears to simply pivot about a point dead center of its slot. Die block positioned in slot by links and arm from weigh shaft as usual. (weigh shaft sitting where camshaft would sit in .I.C. V8). Interesting setup l to have not seen before (doubt having studied half so many of these as you but). This one confirms my general opinion of US heavy engineering back in the day ..deceptively, ingeniously, simple.. once you get your head round it & (in my case) stop trying to solve imaginary complications that ain't there. edit .. couple of replies whist typing
"I've had 'why-don-it-work' sometimes" yarrp.. Thanks for an enjoyable hour, Chris, got any more?
Speaking of Tardis, I just realized what time it must be over there. I'll stop asking questions from New Zealand, where it's currently lunch time tomorrow.
