Those that have been following my Kelsey thread on ME Forum will have seen that I had thoughts of a single cylinder version but was a bit put off as most of the work would just have been a repeat of the Vee Twin. However I have a large folder on my computer of “Future Projects” and one image that I have had stored away there for a couple of years is this little wobble. I think it may be an early Stuart from the days when they had cast cylinders not the current extrusion as the screws would have gone into the cylinder flanges rather than the long studs used on the extruded one.
A bit of time spent on Alibre and I had a design that I was happy with and decided to upload the frame to Craftcloud just to see what a 3D metal printed one might cost as an alternative to making it by fabrication.
The price looked reasonable, so I went back and modified the frame file to be more like a casting by suppressing all the holes and adding a small machining allowance. As mentioned earlier in the year in my A J Weed engine build a lot of the online quotes have a set “job price” that includes printing, post and tax and as this is quite a small item it easily fell within the job price. Playing about with the quantity required showed that I could actually get six frames printed for the same job price as just one so decided that was the sensible option as six frames for £37.00 seemed quite reasonable to me particularly considering that just one spare casting for the Stuart single ST would set me back about £43.00.
I then did a less sensible thing and deleted the quote for the pattern instead of deleting the one for the finished standard and did not realise until the prints arrived just 10 days later. Apart from the holes and no machining allowance I was happy with the way they turned out and after poking a couple of drill bit shanks into the holes was relieved to find they were all 0-2 to 0.3mm undersize. The material is Aluminium and I opted for a bead blasted finish.
With the prints arriving on the 29th December is set myself the task of making the engine before the end of the year so got my finger out in no particular order.
Standard.After quickly rubbing the bottom over some Emery cloth laid on a tile I set it up in the mill vice using a close fitting drill shank to locate the crankshaft bore as my datum point. I took 1mm off the crankshaft boss and the lightest of skims off the port face plus a deeper pass through the middle to reduce port face friction.
The crank boss was drilled out from 3.7mm to 5.8mm then reamed 6mm to take a bronze bush and the cylinder pivot drilled 2.8mm from 2.7mm before being reamed 3mm. The ctr to ctr distance was as drawn at 31mm.
Four plunge cuts with a 2mm milling cutter crispened up the edges of the steam/air ports.
Flipping the print the other way up the opposite ends of the crankshaft and pivot bosses were squared up.
Then onto its sides to run the 3.5mm drill in and then tap for inlet & exhaust M4 x 0.5.
The bottom was then drilled 2mm for some fixing holes, these had not been put onto the design at the time of ordering so were not present on the print.
Setting the casting up for the final sixth time the two linking passages were cleaned out to their 2mm diameter and then counterdrilled 2.5mm for a short depth so the plugs had something to stop against rather than block a port hole.
A length of aluminium was turned to fit the 2.5mm holes and two pieces cut off and Loctited into position to close off the drillings.
