A while back I had the bucket/door for a RC excavator model 3D printed in steel, came out looking great and very strong, but the printed powder/melted result was hard to drill though not too bad. Saved a LOT of time piecing it up, all the undercut shapes and inside corners would have made milling from solid impossible. Quite a neat technology
Quote from: crueby on December 29, 2025, 08:25:50 pmA while back I had the bucket/door for a RC excavator model 3D printed in steel, came out looking great and very strong, but the printed powder/melted result was hard to drill though not too bad. Saved a LOT of time piecing it up, all the undercut shapes and inside corners would have made milling from solid impossible. Quite a neat technologyI remember this. Do you recall what the alloy was named? I see some 3DP services make reference to 'stainless', or 316L, 304L specifically. Some are labelled 'nickel steel'. Some are less forthcoming beyond 'steel'. From what little I've read, the printed material is not softer as a function of the manufacturing process, if anything its hard(er). But I'm wondering out loud if the stainless ingredients, chromium or whatever make it more difficult on that basis alone just like bar stock material. I get along fine with 303 but others can be a bugger. This probably belongs in a 3DP thread, but you twigged my memory
Some of the older 3D metal printing mrthodss used a mix of metals that were printed and then a second sintering process was done to bond the elements together and these are what often resulted in hard to machine parts.The current SLM process just uses a single metal powder and bonds the layers with a lazer. The 316L stainless that I have had dome are just like machining a bit of the same solid bar. See this threadhttps://www.modelenginemaker.com/index.php/topic,12252.msg290225.html#msg290225
The pivot pin is 3mm stainless and threads into a tapped hole in the middle of the port face.You can get some extrusion with stainless steel that does make the diameter over the crests larger than the bar you start with. I just hold a fine file against the thread as it spins in the lathe to knock a bit off the tops of the thread. A finer pitch would not do it as much but I don't tend to use the fine pitches below 3mm.
Re the end of a thread being pushed up, I find it helps to put an under cut there preferably with a radiused tool, this gives a space for the die to run into, the tooth then having no metal to push up. Makes the thread looker neater in my opinion.
