Some valve faces are open-port, and some have cast passages, where only the ports open through the valve face.Here is an open-port design, and it works fine.I would guess a closed design would leak a bit less.At any rate, the force acting on the cylinder/port face would only be generated by the area of the steam ports/passages, which is a small percentage of the entire port face.
I'm not sure I would agree with this unless there was absolutely no leakage across the face.The leakage would complicate things if you consider it..
I do have a tendency not to finish projects when I get another idea about how it "should have been" after starting something.
