Author Topic: A messed up Stuart no.8 Mk I  (Read 2063 times)
Offline vtsteam
Re: A messed up Stuart no.8 Mk I
« Reply #15 on: December 13, 2025, 11:28:31 PM »
Looks great and runs great. That was fast!  :ThumbsUp: :ThumbsUp: :cheers:
Online Chipswitheverything
« Reply #16 on: December 14, 2025, 08:32:43 AM »
This has made the little engine look attractive, and it runs nicely, a nice addition to your collection.  Just a suggestion, would enhance the look if the un-proto-typical slotted screws on the bearing caps were replaced by studs and nuts ... Dave
Offline Sanjay F
« Reply #17 on: December 14, 2025, 08:59:32 AM »
Agreed - that's a good spot Dave; it sometimes needs a second, third, forth, fifth ...........pair of eyes to see these things!  :D.
Let me see what they are and what I have, atm, they could be Whitworth, BA or metric
Offline Sanjay F
« Reply #18 on: December 14, 2025, 09:37:17 AM »
There we go ....... studs and nuts, looks a lot better; not sure what they were actually meant to be, but but 6BA fitted perfectly!
Online Charles Lamont
« Reply #19 on: December 14, 2025, 10:18:26 AM »
Looks good and runs nicely.
If I may also give a couple of 'notes', the slide bars could do also do with hex head screws, and the studs round the cylinder could be neater.
Studs look best with the lengths equalised, at a projection above the nut of about one thread or a little more.
The one at bottom right on the valve chest cover is about right. The ends would be slightly domed.
« Last Edit: December 14, 2025, 11:30:22 AM by Charles Lamont »
« Reply #20 on: December 14, 2025, 10:43:51 AM »
...and those holes on top of the bearings look a bit ragged  :Lol: :naughty: :stir:
Offline Sanjay F
« Reply #21 on: December 14, 2025, 11:18:13 AM »
Yep all noted and let's see what can be done to poilsh it off - I'm guessing the previous or maybe even the original builder was a bit more 'carefree' with the finsh ;D
Offline Sanjay F
« Reply #22 on: December 14, 2025, 11:43:30 AM »
I'm running of nuts 'n' bolts on this engine, hopefully Santa will restock shortly
Slidebar cheesehead screws now changed, bearing caps tidied up and I'll take a look at the cylinder head bolts, I have trouble rounding the ends, but I guess in the lathe with a file maybe .......
Right .......I'm off to London to the Pantomime with the family.............. oh no you're not .......... :ROFL:
« Reply #23 on: December 14, 2025, 06:21:01 PM »
Sanjay, another beautiful steam engine for your collection. I also like the green color.
Well done! 👍
Offline samc88
« Reply #24 on: December 14, 2025, 10:05:18 PM »
Nice work Sanjay
