Help! > Machines, Tools and Fixtures
DUplex Toolpost Grinder
(1/1)
Twizseven:
I  have had a Dupex Toolpost Grinder for several years but never really needed to use it.
I now need to very slightly reduce the diameter of a hardened 90 degree seatcutter.  I have  made and fitted guards for the wheel and the belts, ordered a new belt but am struggling to find a source for suitable grinding wheels.
The wheels need to be 3″ diameter (or 75mm), 1/2″  thick and with a bore of 1/2″.  I have managed to source some 1/4″ thick wheels but cannot find any 1/2″ thick.
A Midlands grinding wheel specialist can machine a 5″ one down to 3″ but will have a 2-3wk wait.  Does anyone have any ideas on sources or even have a spare wheel they have no use for.
It is a Model D22A running at 1100rpm.  Capacity is given as 3″ x 1/2″.  Would I be correct in thinking that I could go smaller, say to 2″ diameter, safely.
Many Thanks,
Colin
Chipswitheverything:
Might be worth checking out Hemingway to see what they have for the Quorn grinder.  My Quorn is presently set up with a wheel about 3" dia and 3/8" thick, one of the older wheels supplied with my Quorn kit from MES originally. Dave
Navigation
[0] Message Index
Go to full version
