Thanks Sanjay Next up is the connecting rod. I'll build it the same way as on your bottle engine. I just need to determine the exact distance between the holes on the large and small ends. That'll be a bit tricky in this tight space.The guide for the slide rod should also be like on your engine, with square steel tubing. But I'm wondering why the square tubing is rotated by 45 degrees. What's the advantage of that?
Thanks, Paul.I think I might not use any paint. The brass can darken on its own and maybe in 50 years it'll look like the motors Sanjay always finds. 😉Michael
Great, then you can build a bottle engine too.
