I think the barstock build thing has been changed a lot by the advent of CNC.
With CNC, you can basically cut a casting out of a solid block, and so that is really a whole new ballgame, if you are into such things.
I am not sure if CNC work is considered strickly a barstock build.
Perhaps it could be called "barstock-plus".
And 3D printed metal parts also sort of blurs the line between traditional and new building methods.
Its all good as far as I am concerned, but I am interested in anything casting or casting related, since I have gotten into that game, and had some luck with it.
Barstock builds are a great way to get started building engines.
If I had initially had any success with that method, I would have probably stuck with it, but I ruined every part I tried to make from barstock.
I have all those ruined pieces, but I put them away in a box, since they are painful to look at.
One of the cool things about making your own castings is that if you botch machining a part, you just cast another one; no big deal.
3D modeling, and the things that spun out/off of that process have changed and will continue to change the hobby quite a bit, in my opinion.
From a design standpoint alone, 3D modeling had made tremendous improvements in the hobby and associated drawings/models.
The hobby is changing for sure, and I think in most respects for the better.
Edit:
Apologies to maury for chatting up his build thread......
