Hi Chaps….
It’s been a little while since I have made time on this project!
The engine is now running well and close to final finishing
Without gaskets it runs at 3-5 psi which is encouraging to say the least
I did run the engine partially in on the lathe with the correct shims so to not damage the bearings
All went well so I went straight onto compressed air to keep running in
Now seems well sealed cylinder wise , a little work needed to polish the top of the standard to better seal the throttle arm and I think it’s good to go
So just a throttle arm to make as I’ve robbed one from another model lol 😂 and some gaskets …
I have recently found a lovely little o ring internal booring bar that just fits in an 1/8” hole that allows me to insert o rings on the piston rod to bottom cover, this is a bit of a game changer in terms of leaks and friction, It works so much better than graphite yarn !
