Involute cutters can't physically produce an undercut as the blade would need to be wider than the narrowest gap between teeth and unlike a planer or hob only cut one gap at a time. They can cut a modified profile that eliminates the need for undercut which is whare the profile shift comes into it.
Quote from: Jasonb on November 12, 2025, 11:26:34 amInvolute cutters can't physically produce an undercut as the blade would need to be wider than the narrowest gap between teeth and unlike a planer or hob only cut one gap at a time. They can cut a modified profile that eliminates the need for undercut which is whare the profile shift comes into it.Poppycock:
