This is the Mark I version of the Stuart 10h. It does not have a tubular trunk guide, but has a single-sided cross head. Not sure when it changed to the tubular version?
There are several odd things about it:
- The crosshead guides are missing but have clearly never been there as there are no holes.
- The cylinder does not mate correctly with the soleplate
- Someone has got a bit trigger happy when drilling the holes in the cylinder
- There's a huge blob of solder holding the exhaust in place
- The entire engine has never had a primer or paint on it
- The piston rod end has been beaten over to try and keep it fixed to the piston (it didn't work!) - see video
- The valve chest cover has never been machined to size and it never had the 'S' on it, so must be a later addition
In my humble opinion this engine was never a runner, although I did try pumping some air through it
I think I'll start with trying to get the cylinder sorted before moving onto the crosshead guides, new piston and rod. I cleaned up the soleplate and it looks like a brand new casting, I even had to file away some flashing; I may actually paint this one given the fact it was never finished......
I have a couple of questions.
1. Has anyone got the drawings for a Stuart 10h Mark I?
2. How do I sort the messy solder out; is it soft solder and will just melt away nicely......?
https://youtube.com/shorts/rbw4oq6WAsg?feature=share
