Author Topic: Petters Pump  (Read 7718 times)
Offline maury
    • Lone Star Engine Works
Petters Pump
« on: August 30, 2025, 05:18:36 PM »
Time for a new project. I saw a project on Smokstak where a guy was restoring a Petters Pump, and I just couldn't wanting to build a model of it. The project was mostly dis assembled, and I'm not sure all of the parts were there. Additionally, I was unable to see the cylinder and valving internals from the pictures. Additionally, I don't have access to the actual pump, so I had to print out the pictures and scale the design from that. So this will not be a scale model, but a close approximation with a little artistic license.
I'm at the point where I have most of the parts modeled in Solidworks, and have built an assembly and have done checking for the parts fitting properly. There are still details to address, mostly with the valving, so it continues.
This will be an excellent companion for the Webster Chicago I'm in the process of completing. The project will be made from castings, so there will be a lot of pattern work. If my health holds up ok I'll be pouring the parts in aluminum, then on to the shop....
maury
Re: Petters Pump
« Reply #1 on: August 30, 2025, 05:33:27 PM »
Neat looking pump! Will be watching along.    :popcorn:
Re: Petters Pump
« Reply #2 on: August 30, 2025, 05:34:35 PM »
That brings back some memories, will be fun to follow along.
Offline maury
Re: Petters Pump
« Reply #3 on: August 31, 2025, 02:10:59 PM »
Thanks for checking in guys.
Dave, I have the memories too. Also still have the Gould Pump. Maybe someday I'll finish my Pacific and connect it up.
maury
Offline CI
Re: Petters Pump
« Reply #4 on: August 31, 2025, 04:00:44 PM »
Looks great !
Re: Petters Pump
« Reply #5 on: August 31, 2025, 04:02:58 PM »
What sort of size are you aiming for? and what is that in relation to the orginal?
Offline maury
Re: Petters Pump
« Reply #6 on: August 31, 2025, 05:30:26 PM »
Thanks for the comments.
Jason, From what the pictures of the original look like, its about half size. On the model the pulley and bull gear are about 6in and 5 1/4 in. The bore is 1 in and the stroke is 2 in. I wanted about this size to go with the Webster Chicago I'm Building.
maury
Offline Alyn Foundry
Re: Petters Pump
« Reply #7 on: August 31, 2025, 07:48:06 PM »
Is this a JB Petter of Yeovil Somerset?
Online Charles Lamont
Re: Petters Pump
« Reply #8 on: August 31, 2025, 08:02:21 PM »
Seems to be Peter's Pump Co, Kewanee, Illinois
Re: Petters Pump
« Reply #9 on: August 31, 2025, 08:30:09 PM »
I dont think so - that one made hand powered pumps like you'd see out in the yard. And it only has one 't' in the name.
Offline maury
Re: Petters Pump
« Reply #10 on: September 01, 2025, 05:45:02 PM »
Y'all, the pump is the Petters pump - Mfg. by Petters Pump Co. Kewanee, Illinois. It's printed on the air dome.
They have made several versions best I can find. One version is a hand pump with  rack moving the piston and a partial pinion on handle for manual pumping, It uses the same or similar pump parts as the one I'm modeling.
Re: Petters Pump
« Reply #11 on: September 01, 2025, 06:24:09 PM »
Seems the advert had one T as does the one on Smokstak with the fast and loose pullies
https://www.smokstak.com/forum/threads/peters-belt-driven-piston-type-water-pump.215718/
« Last Edit: September 01, 2025, 06:30:25 PM by Jasonb »
Offline maury
Re: Petters Pump
« Reply #12 on: September 01, 2025, 07:34:31 PM »
Yup, it seems you are correct. Seems my eyesight is also going bad. I'll have a lot of stuff to correct, including my pattern for the air dome.
Thanks for the good catch.
maury
Offline maury
Re: Petters Pump
« Reply #13 on: September 20, 2025, 08:49:09 PM »
After almost 3 weeks on medical time out I'm feeling better and soon to be back. In the mean time I sent the patterns for the pump design to a friend who cast them for me. I think my foundry days are soon coming to a close. I'll miss it! I'm quite pleased with the castings-he did a great job- and can't wait to start cutting metal-After Dr's approval.
Enjoy the pics.
Offline samc88
Re: Petters Pump
« Reply #14 on: September 20, 2025, 09:41:12 PM »
Nice looking castings Maury, glad to hear you are on the mend
