There is a video on ytube of someone bending a long coil of copper tubing around a pipe, and he used the frozen water method.The pipe was larger diameter, such as 1/2" or 3/4".I suspect that the frozen water method would also work in small diameter tubing, but I have not personally tried it.
Quote from: CI on August 26, 2025, 10:24:07 amThere is a video on ytube of someone bending a long coil of copper tubing around a pipe, and he used the frozen water method.The pipe was larger diameter, such as 1/2" or 3/4".I suspect that the frozen water method would also work in small diameter tubing, but I have not personally tried it.Thanks, I might try it out on the offcut.As it is I made a little former as per JCvdW's suggestion, stopping to anneal about 1/3 of the way through bending. After annealing the pipe was really soft (to be honest it felt too soft), in the end I doubt it was necessary given that it's new pipe and such a small diameter. The final result is good enough, there's just a little flattening at the curve and a small wobble I can remove with finger pressure latter but there's no interruption to air flow.
Paul, in the Kozo method that has been posted here, he shows using a fairly snug fitting groove in his bending mandrel. Vertical sides on the groove. Part of the point of this is to hold the sides of the tube your bending so that they don't pooch out and make an oval. It does help quite a bit. I think your V shaped groove might have allowed the edges to bend out more than if they'd been vertical.
Anneal first. Make a bending jig that is just a pulley with a 1/8" groove 1/8" deep. Make it from wood or metal. 1" diameter will work.You can fill the tube with sugar, plug each end. In order to make the sharp bend start with the tube much longer than you need. If you feel resistance part way, stop and anneal again.
