QuoteSo, does copper also evaporate while melting?Copper is not a volatile metal like magnesuim so there will be low loses adding it and will persist when remelted. As for melting loses when remelting it can be a guessing game but I found over the years melting cast iron is no problem provided you melt the same known scrap that has given a good result in the past.
@CI for pouring temp I go by whether a 1/4" round steel stir rod comes out shiny pointed, vs. clumped with melt.The steel stiring rod is an interesting method.
Perhaps measuring sulphur content would be helpful, but I will be using the same treatment regardless of what iron scrap I use to make ductile iron.
