6mm stroke w/15mm displacer = roughly 10.6 cc displacer swept volume10mm stroke w/9mm power piston = roughly 6.4cc swept volume10.6 to 6.4 = 1.65 to 1
Quote from: vtsteam on September 02, 2025, 06:51:43 pm6mm stroke w/15mm displacer = roughly 10.6 cc displacer swept volume10mm stroke w/9mm power piston = roughly 6.4cc swept volume10.6 to 6.4 = 1.65 to 1I get different figures0.6 stroke x 1.5 displacer = 1.8cc1.0 stroke x 0.9 power piston = 0.64cc1.8 to 0.64 = 2.8 to 1The Raab I have just finished would work out to 2.17:1
Just as a suggestion, Paul, find your displacer stock in your tube supply first -- ideally aluminum. Bore the inside to clean it up. Then turn the outside down (with the tube mounted on a wooden mandrel) to give a thin wall.Then just make a displacer cylinder from a random oversize dia solid rod and drill and bore it out to about 1.5 mm oversize for the OD of the displacer. Then put the displacer cylinder onto another temporary turned hardwood mandrel and turn the outside down as thin as you feel comfortable with.
You can use either silver or brass braze for the displacer cylinder end if it is of steel. Stainless would have required silver. I usually braze the end on before final turning/thinning of the displacer cylinder. I leave a small step at the very end so the end piece maintains a reasonable joint width.If you are making the cylinder from solid, you can leave the end closed, and not have to braze one on. Boring to a thin end can be tricky, but of course do-able. Or you can bore to an end on long stock, then carefully cut it off close -- with careful measurement -- lots of ways to skin a cat.
