the second one down is nice and rigid but not sure about using that type of tip for boring?The others don't look like there up to the job?
Hmmm, I have no idea how to grind a tool bit, ...
It's a pity you did the OD first and cut it off from the bar as that limits your options for holding. You will also have to watch out when holding it by the OD for boring that you don't get distortion as the wall thickness comes down which when removed from the chuck can cause a trilobed hole to form
