I would say he has picked it up how to melt and pour iron pretty much overnight.
One recent melt with seven back-to-back pours in one day, and four more back-to-back iron pours today totaling 72 lbs.
Hopefully he will post more videos.
Iron is not that difficult once you get the hang of it, and use appropriate heat shields in strategic places.
Edit:
When doing multiple pours, one has to decide on how large a crucible to use.
He is using a #12, which is good for about 30 (+ -) lbs of iron usable, not brim-full.
A larger crucible will hold more iron, but is more difficult to lift out and pour.
A full #20 is a very heavy pour, and not only do you have to lift 50 lbs or so of iron, but the crucible has significant weight, perhaps 12 lbs, and then the weight of the pouring shank.
A full #20 is about the most I would try to hand-lift and pour.
Using a #30 at its capacity pretty much requires a crane and pouring cart, unless you are a very hefty person.
Technically speaking though, he could have poured the entire 72 lbs in a single melt if he used a #30 crucible.
Also, something to consider, if you spill a #12, that is not that big of a deal.
If you spill a #30, that can be a pretty big deal, depending on which way it splashes.
