Nice! For drills that small I've always used the numbered 60-80 sets that come in the tiny index cases (or did, anyway) that I had from ship model work, meant more for use with hand pin vises. Never tried the stepped shank type you got. Did you have to 'peck' at the holes to clear chips, or use any oil? The ones I've used are fairly flexible, so really needed a spot drill to get them started without skating, same with these?
The tape+super glue didn't hold up well under the flood coolant, and the part detached at the end, but thankfully no harm done. Brass will be machined dry.
Would turning the center diameter first, then drilling the arbor hole second, be a better order of operations for such a thin wall? Just a thought... Kim
Quote from: kvom on December 31, 2025, 10:27:41 PMThe tape+super glue didn't hold up well under the flood coolant, and the part detached at the end, but thankfully no harm done. Brass will be machined dry.Circling back to this post. I've found that powder-coat masking tape from McMaster-Carr is coolant-resistant even under full flood coolant in a machining center. I put a layer of tape on the sheetmetal blank, a layer on my aluminum "spoilboard," and stuck the tapes back-to-back with cyano. I had pre-drilled and tapped holes in the spoilboard, drilled clearance holes through the glued-down sheet and then put in some safety screws for the heavier profiling cut. Once profiled, the parts came off relatively easily with a single-edge razor blade. I have done the method using regular blue masking tape, and it does not hold nearly as well as the powder-coat masking tape. The latter is thinner, not crinkly, and gives much better control in the thickness dimension (Z).
That pinion spool came out very nicely! But if you made it larger, won't that affect the PD of your pinion and bump the whole gear chain out of alignment? Or maybe you didn't change the size and I misunderstood?Kim
