The pillars are looking good! Have you made the frame yet? Or will that be coming next?Kim
Making a start on the 4 pillars that connect the front and rear plates, I immediately machined 2 of them slightly short. So they'll go back into the brass rod depository. But I did succeed with one of the top pillars, which starts with 3/4" diameter rod. Since all 4 need to be the same length between the plates (2.375"), I put together some gauge blocks and locked a caliper as a visual reference. My goal was to do all of the machining with a 1/8" parting blade. Keeping it locked in position in its mount meant that I could use the Y-axis DRO to set all of the varying diameters. I'd only remove the tool at the end to machine the needed chamfers.I'll do the second top pillar next time, but will need to use 1" diameter rod for the lowers instead of the the 1.125". What do the numbers on the bottom part of the 2" gauge block refer to ?? Good work happening here Cheers Willy
Makes sense! And yes! Brass is very expensive! You don't want to do a lot of experimenting with the frames in brass How close are you on your CNC mill? That's quite a project in itself.Kim
Is the die a split one? If the set screw is too far in it would make the threads too shallow and not go in the nut.
