Are you hoping to do a scale model or just a winch? Your last comment about spending 100s of hours suggests you just want a basic representation as a scale model that replicated the details shown would entail quite a bit of work.Also what sort of sizes are you able to accommodate on your machines? if doing a detailed representation then that does become a bit easier if the sale is larger unless you like watch making.It would make a nice model though.Chris. I take it that the valve is sectioned along the length of the engine, would I be right in thinking that if sectioned across the engine it would show tow flanges each side so a total of 4 outlets. The top to for outside admission and the lower for inside admission of steam and the pair not feeding steam then carry the exhaust?
Quote from: London_lighterman on June 06, 2025, 08:55:52 pmHaving a local model engineering club allows me to be among likeminded "nutters" but a great source of experience and suggestion.Greetings from Essex and hope you enjoy the forum. Which model engineering club is it as there's nothing my side of London which I can find?
Ah, yes, the central valve is the same type of spool valve. The drawing makes it look like ports on either side, but what they did was have a ring around the spool to maximize the area of the port for best flow. The spool itself has openings through the center to allow flow between the ends just like the spool valve on the cylinders. Here is a marked up diagram of that center control valve:The red arrow shows the steam inlet, and the blue the exhaust outlet (those can be swapped if need be, makes no difference to the function). The green and pink arrows show the pipes leading to the cylinders. In the cross section on the right side, the red and blue arrows show the inlet/exhaust, and the green and pink dots show where the pipes to the cylinders connect in on the valve body casting - they did not show these in the cross section. I show them over on the side where they drew one side of the ring - they would actually be in the center of the ring. If the valve spool is moved up, the inlet steam would be sent out the pink pipe, and the exhaust connected to the green pipe. If the valve spool is moved down, the steam would go through the center of the spool and connect to the green pipe, and the exhaust connected to the pink pipe. Does that make sense?
London,I assume you are or were a crane operator. Looks like an interesting project. But way over my pay grade, haven't done much steam myself. Welcome to the forum and I think you'll find a bunch of folks who know whats involve in that drawing!Art
