Author Topic: hello from London  (Read 8903 times)
Offline London_lighterman
hello from London
« on: June 06, 2025, 08:55:52 pm »
Hello all.
I thought I would say hello and an idea I have for a project.
My time as a model engineer has produced a few things and a considerable amount of swarf and some perfectly good scrapped bits laying in the box.
Having a local model engineering club allows me to be among likeminded "nutters" but a great source of experience and suggestion.
Attached is an idea for a model, I remember these winches still running on some of the older ships and have fond memories of working "under the hook" as we referred to it in my profession.
My interest is a very broad church be it on wheels, the water of screwed down and going round. I have avoided models the take off turning 100's of hours of work into a kit really doesn't send me!
Re: hello from London
« Reply #1 on: June 06, 2025, 09:02:47 pm »
Welcome to the group! Lots of us likeminded nutters here!  :Lol:
I have the same catalog that Hyde winch picture is from, lots of great information in there. I also got interested in them after seeing similar ones on a Liberty Ship in Baltimore. It would make a great model!
« Reply #2 on: June 07, 2025, 12:02:05 am »
Hi there!  Welcome to the forum!  :cheers:
« Reply #3 on: June 07, 2025, 12:09:53 am »
Welcome to MEM!
Offline CI
« Reply #4 on: June 07, 2025, 02:53:45 am »
Welcome to the group.
I had an opportunity to purchase a hoist one time.
It was sitting by the side of the road in front of an equipment company.
It was not in particulary good condition, and they wanted $750.00, which was quite a bit of money in the early 70's, so I did not get it.
Very nice choice for a model build, in my opinion.
I found some hoist images in an Audel's book.
I will start a thread an post a few.
Offline CI
« Reply #5 on: June 07, 2025, 03:17:27 am »
For a minute there, I thought I was seeing dual piston rods, but it is just two round crosshead guides.
« Reply #6 on: June 07, 2025, 03:49:59 am »
The neat thing about the mechanism is that its one eccentric per cylinder, with a spool valve that is switched between inside admission and outside admission to make it go forward and reverse. The center valve controlled by the operator swaps the steam/exhaust and also acts as the throttle. Really neat setup.
Offline CI
« Reply #7 on: June 07, 2025, 04:12:23 am »
I missed the reversing valve completely, but did notice the unusual plumbing.
So does this engine use piston valves? to prevent valve lift when reversing the engine ?
The Soule Speedy Twin is the only D-valved engine I am aware of that uses a reversing valve, and the only way it can do this without valve lifting is to have a check valve built into the D-valve.
The Dake also had a reversing valve like that, but its internal construction prevented any valve lifting, since the valves are part of the inner piston.
« Reply #8 on: June 07, 2025, 05:17:43 am »
Yeah, piston valves can be plumbed so the steam comes in either at the center, inside admission, or at the ends, called outside admission. Swapping between the two makes the engine run the opposite way. As you suspected, doing that with a d valve will cause the valve to lift. ThIs hoist engine has the same setup as the first steering engine I built. The same end result can be done with the double level/four port arrangement  that steam shovel slew/crowd engines used, which is how I am making my current steering engine. Its amazing how many different valve arrangements have been invented over the years.
Just looked back at the drawing in the first post, the valve shown there is the control valve that the operator lever moves. Its also a piston valve, lookes a lot like the cylinder valves.
« Last Edit: June 07, 2025, 05:21:56 am by crueby »
« Reply #9 on: June 07, 2025, 07:10:29 am »
Are you hoping to do a scale model or just a winch? Your last comment about spending 100s of hours suggests you just want a basic representation as a scale model that replicated the details shown would entail quite a bit of work.
Also what sort of sizes are you able to accommodate on your machines? if doing a detailed representation then that does become a bit easier if the sale is larger unless you like watch making.
It would make a nice model though.
Chris. I take it that the valve is sectioned along the length of the engine, would I be right in thinking that if sectioned across the engine it would show tow flanges each side so a total of 4 outlets. The top to for outside admission and the lower for inside admission of steam and the pair not feeding steam then carry the exhaust?
« Last Edit: June 07, 2025, 07:15:27 am by Jasonb »
« Reply #10 on: June 07, 2025, 01:18:24 pm »
Hi Jason,
Nothing that complex, looks very like a D valve setup as for the passages. Here is a cross section of what my steering engine model was:
The green pipes on the right are the two incoming pipes from the control valve - one would get steam, the other takes the exhaust, depending on how the control valve was moved. The yellow dot at the middle of the spool valve indicates holes in the valve spool so the two ends are connected. If the steam comes in the pipe in the center, its 'center admission', and in this diagram the steap would go to the lower end of the cylinder and make the piston move up. If the steam comes in the other pipe, then its 'outside admission' and in the postions in this diagram the steam would go to the top of the cylinder and push the piston down. Thats how it reverses the engine with just the one eccentric. Hope that helps?
Offline Sanjay F
« Reply #11 on: June 07, 2025, 02:56:57 pm »
Greetings from Essex and hope you enjoy the forum. Which model engineering club is it as there's nothing my side of London which I can find?
« Reply #12 on: June 07, 2025, 06:42:13 pm »
Welcome to the Forum  :ThumbsUp:  :ThumbsUp:
« Reply #13 on: June 08, 2025, 03:17:32 am »
London,
I assume you are or were a crane operator. Looks like an interesting project. But way over my pay grade, haven't done much steam myself. Welcome to the forum and I think you'll find a bunch of folks who know whats involve in that drawing!
« Reply #14 on: June 08, 2025, 07:07:58 am »
Chris I was enquiring about the central valve that alters direction, not the actual piston valve which is no different to others I have made like the recent A J Weed.
It is the valve off to the right of your image that is connected to the green pipes and then mirrored for the other side of the twin engine.
