Engines > From Plans
Philip Duglos Oddball Hit &Miss six Stroke Engine
Roger B:
Looks to be a fun project, I will be following along :) :) :wine1:
I guess that this design allows for extra expansion of the fuel mixture, which gives a similar effect to the Atkinson cycle :thinking:
wbernhard:
Regarding the answer from "crueby"
"Did a bit of searching on 6 cycle engines - what I found was that they take an extra revolution and fire a second time to more completely burn some un-burnt gasses left in the cylinder from the main firing. So, it does intake/compress/fire/exhaust on the first two revolutions, then compress/fire again on the third revolution, then starts over again."
After looking at Phillip Duclos's drawings, my conclusions are as follows:
Based on the shape of the exhaust valve cam and the crankshaft-to-camshaft ratio of 3:1, I conclude the following:
The engine simply makes an additional third revolution with the exhaust valve open. With the exhaust valve open, it can neither draw in nor generate compression. It won't fire a second time either! Why should it?
Best regards, Charly
rdean33422:
This is my 6 cycle double acting engine I completed a while back.
http://www.youtube.com/watch?v=jmu07b3MqHA
It does operate like Charly said but it does suck in air and blow it out during the 5 and 6 cycles..
Ray
Bruno Mueller:
I made the next parts.
The bronze bushings are due to arrive next week.
I still have to make the crank bolt. The crankshaft axles made of 1.7225 (42CrMo4) were pressed in with Loctite 638.
I plan to start the engine with a round pulley and starter cord. That's why there are no claws on the flywheel axle.
After the two flywheels were finished, I had to clean the lathe and the surrounding area from the gray cast iron dust.
Navigation
[0] Message Index
[*] Previous page
Go to full version
