Author Topic: Boring Noise & Finish  (Read 9019 times)
Re: Boring Noise & Finish
« Reply #30 on: May 09, 2025, 07:14:04 AM »
Some interesting experiments  :ThumbsUp:  :ThumbsUp:
Another option for small holes is to use an end mill as a boring bar. I set the cutting edge level and on centre height.
« Reply #31 on: May 09, 2025, 07:41:37 AM »
What is the diameter of the finished hole? Is it still the 10mm diameter that caused the original problem, or larger?
« Reply #32 on: May 09, 2025, 08:53:32 AM »
That would seem to be a very rigid alternative but it begs some questions!...
1 Does it give a good finish?
2 It looks like you've got it in a square holder, is that right?
3 What sort of depth of hole could you get with a 6mm end mill?
4 Would a starting hole of say 7mm suffice?
« Reply #33 on: May 09, 2025, 08:58:15 AM »
I started with a 10mm hole (max size in tailstock chuck). I mentioned earlier in the thread that I made a mistake in the OP - it's a 6mm bar not 8mm so a starter 10mm hole should be ok. I didn't measure the final hole, I just kept cutting until I achieved a decent finish as it was just an experiment on some scrap... which has been returned to the scrap bin as I'm sure I'll find a use for it  ;D
« Reply #34 on: May 09, 2025, 09:40:21 AM »
I have used this technique successfully and got a good finish in holes from 3mm diameter upwards. I got the idea from Jo or Jason, I don’t remember who.
I have a square holder for 6mm diameter shanks that came with a set of HSS boring bars and a homemade rectangular holder for 3mm shanks.
I am not sure how deep I have gone, maybe 15mm, but this was limited by the size of the job not the technique. The cutter needs to be offset a few degrees so that only the tip will cut.
7mm would work with a 6mm end mill. I always remove as much as possible by drilling.
HSS end mills will be less likely to chip or break than carbide however I use Proxxon carbide end mills for 2 and 3mm cutters as they have 3mm shanks and are easier to use in small spaces.
« Reply #35 on: May 09, 2025, 03:02:35 PM »
Thank you Roger, that's very helpful, I'll pick up an end mill and give it a try.
