Author Topic: Mount Trapezium  (Read 52037 times)
Re: Mount Trapezium
« Reply #285 on: May 29, 2025, 06:59:56 AM »
You might want to do a bit more shaping of the lower yoke as it may be hard to file the last bit away once it is soldered without catching the protruding boss.
Offline redhouseluv
Re: Mount Trapezium
« Reply #286 on: May 29, 2025, 08:43:04 AM »
Oh dear, it may be a bit late for that this morning, I had an early start! (see below)
Offline redhouseluv
Re: Mount Trapezium
« Reply #287 on: May 29, 2025, 08:44:40 AM »
I see what your saying, I may have to live with that gap, but if the solder has worked I will be a happy man  :D
Offline redhouseluv
Re: Mount Trapezium
« Reply #288 on: May 29, 2025, 08:57:49 AM »
1 joint bit dodgy
What should I do with this - all the other's aren't too bad, but this? Should I do something about it?
Offline uuu
Re: Mount Trapezium
« Reply #289 on: May 29, 2025, 09:03:21 AM »
Pickle it to get it really clean again and give that one another go.  Put flux on all the joints,  just to keep the others clean during the heat up.   Unless you grossly overheat it, the other joints should stay secure.  Whether you'll be able to close up the gaps while it's hot is a good question, though.
Wilf
« Last Edit: May 29, 2025, 09:09:22 AM by uuu »
Re: Mount Trapezium
« Reply #290 on: May 29, 2025, 09:06:04 AM »
Pickle, flux and go again.
You have got the rod hot enough but not the yoke that is why the solder has only taken to the rod. But the joint does look a bit open at the top so check is is all lined up correctly
PS best not to use your collet blocks, piece of scrap is better
PPS Clean the sink before your other half see it :-[
« Last Edit: May 29, 2025, 09:10:51 AM by Jasonb »
Offline redhouseluv
Re: Mount Trapezium
« Reply #291 on: May 29, 2025, 09:24:49 AM »
Thanks Wilf & Jason
I'm glad I can do it again!
Luckily that's MY sink in the workshop, and she just walks past it looking disapprovingly at me ;D
Offline redhouseluv
Re: Mount Trapezium
« Reply #292 on: May 29, 2025, 11:30:01 AM »
I think I'm done, it's far from perfect and there's a couple of holes which I can fill with soft solder, and then carefully hacksaw the arms off. Still a bit more cleanup to be done, but will do that later - thank you all for the guidance on this part
Re: Mount Trapezium
« Reply #293 on: May 29, 2025, 02:15:21 PM »
Nice result, and learned a lot for the next projects! One other thing I've done sometimes when there is a gap on one part of a joint is to put in little snippets of brass sheet stock to fill the gap, that gets the opening small enough for the solder to stick both sides and fill the gap. Or, like you say, some soft solder will fill it as long as there is enough other hard solder to hold the joint - thats fine on parts like this that won't be seeing lots of heat in use like a boiler would.
 :ThumbsUp:    :popcorn:
Offline redhouseluv
Re: Mount Trapezium
« Reply #294 on: May 29, 2025, 03:05:43 PM »
Thanks Chris and everyone - great advice and learning has been exponential over the last few weeks
I couldn't help myself and had to have a visual check of where I am on the overall project and how the pieces which took so long to make fitted into it......
https://youtube.com/shorts/EPSruujb9FQ?feature=share
I've pulled the shutters down on the workshop, it'll be at least a week before they come back up..............will be watching all your projects though  ;D
Re: Mount Trapezium
« Reply #295 on: May 29, 2025, 04:24:10 PM »
Motions look good on the parts, almost like a clock!
Offline uuu
Re: Mount Trapezium
« Reply #296 on: May 29, 2025, 04:46:57 PM »
If the part is to be painted, you could fill any gaps with a smear of car body filler.  Easy to sand back as required.
Wilf
Re: Mount Trapezium
« Reply #297 on: May 30, 2025, 07:21:45 PM »
Looking good Sanjay!
  • Oregon
Re: Mount Trapezium
« Reply #298 on: May 31, 2025, 02:42:30 PM »
Great progress! That motion is going to be hypnotic to watch when all done. :ThumbsUp: :ThumbsUp:
Offline redhouseluv
Re: Mount Trapezium
« Reply #299 on: June 07, 2025, 02:55:01 PM »
Finally back home and straight in the workshop
The piston rod pivot is the next part to be made and when I made the bar (see pic) the spacer (centre section) was 5/32" diameter. I need to make the hole in the brass bush the same size and I'm not sure I'll get away with it as that would mean a very thin wall; 0.187" - 0.156"/2 = 0.015"?
I'm thinking of making the bush 0.250" and then I'd get a wall thickness of 0.047"  - I can't see that impacting anything?
The piston rod pivot pivot fits into the slot in the final photo
« Last Edit: June 07, 2025, 03:00:09 PM by redhouseluv »
