Author Topic: Well pump as a model.  (Read 14416 times)
« on: March 30, 2025, 06:39:01 PM »
I should really use my free time to work on the ME Beam steam engine, but I think I'll get on with it in the fall.
There are a few aluminum castings on the shelf. I bought them at an exhibition in Austria, and I was fascinated by this pump.
So I started on it today. The piston is a standard 1/2-inch check valve. To prevent the brass piston from sliding too easily in the aluminum, I thought I'd use a thin brass tube from the sink drain. I only need to remove 1 mm in diameter from the check valve. I drilled the hole on the lathe so that the brass tube clamps easily in the aluminum. Using a freshly turned piece of beech wood, I clamped the cylinder upside down in the lathe chuck and machined the other side. It all worked quite well. The aluminum is very easy to machine.
Re: Well pump as a model.
« Reply #1 on: March 30, 2025, 06:48:12 PM »
The foot valve has a brass ring. I think it's better this way.
The check valve can be easily held and worked on with a 1/2-inch sleeve.
All the parts are screwed together. O-rings are used as seals.
In any case, I made good use of the somewhat stormy and wet Sunday, and the beginning is made.
Offline Sanjay F
« Reply #2 on: March 30, 2025, 06:59:24 PM »
Now that's something quite different from the usual castings! Who makes the castings and it also makes me wonder what else to they make?
« Reply #3 on: March 30, 2025, 07:17:09 PM »
« Reply #4 on: March 30, 2025, 07:59:50 PM »
That is a beautiful pump kit!
Offline Sanjay F
« Reply #5 on: March 30, 2025, 08:14:35 PM »
Look here:
https://mbi-design.de/wp/
I shouln't have looked, but couldn't help myself!  :D Some very nice things, I particularly like the piston water pump https://mbi-design.de/wp/produkt/kolben-wasserpumpe/
« Reply #6 on: April 06, 2025, 05:33:40 PM »
I worked on the pump again today.
The pulley mount was made, as was the water basin and base.
The water basin is only attached to the base with two O-rings. I think that's okay.
The drive shaft is getting ball bearings.
That means almost all the cast parts have been processed.
« Reply #7 on: April 06, 2025, 05:41:19 PM »
And here are almost all the parts put together.
<a href="https://www.youtube.com/watch?v=wVO_leGKNh8" target="_blank">http://www.youtube.com/watch?v=wVO_leGKNh8</a>
« Reply #8 on: April 06, 2025, 06:28:46 PM »
The pump is coming together quickly, looks great!
« Reply #9 on: April 06, 2025, 06:45:20 PM »
Nice!
« Reply #10 on: April 07, 2025, 12:13:27 AM »
Nice progress Michael!
« Reply #11 on: April 07, 2025, 06:58:29 AM »
That is a very handsome Pump and I get a little sentimental seeing it  :ThumbsUp:
Per     :cheers:
  • Oregon
« Reply #12 on: April 07, 2025, 03:03:33 PM »
Reminds me of watching the old well pump run as a small boy. Ka-chunck Ka-chunk Ka-chunk...
« Reply #13 on: April 19, 2025, 06:37:57 PM »
I had time and was able to continue working on the pump. The hand lever is installed and connected to the piston.
I pumped myself a beer right away.
Michael, cheers 🍻
« Reply #14 on: April 19, 2025, 07:29:46 PM »
Now THATS a useful pump!   :Lol:
