Supporting > My Workshop
Pallet Jack needs wheels
Art K:
Yeah I had to change the wheels on the pallet jack at work, didn't have any trouble though.
uuu:
I've not tried drilling a roll pin - I always imagined that the springy material might be semi-hard - and the shape will grab the drill. The protruding bit can already be spread out a little, making it hard to press through, so grinding it off before pressing in a drift has worked for me.
Wilf
Art K:
while I'm thinking of it, Have you tried a roll pin punch? The 1/4 inch one I use at work is McMaster's Part Number 3421A41. Keeps the punch centered while you wail on it!
kvom:
That's the first thing I tried, but the wheel mount moves so it's hard to get any force onto the pin.
ShopShoe:
I have run into "stuck" pins that were mushroomed on the end from someone previously trying to get them out with inappropriate tools.
Regarding, the mount moving: Is it possible to remove the caster so you can clamp it in a vise?
--ShopShoe
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
