Engines > From Kits/Castings
The Bolton -Bertinat -Bailey Triple expansion engine
<< < (21/78) > >>
steam guy willy:
Hi Charles , yes I can see what your saying  and to get a steady feed from the cross slide I grip the handle with both hands and press them against my body and then turn the handle with a steady rocking action to get a steady controlled feed  ?!!!
\cheers for looking in
Willy
steam guy willy:
Back in the WKSP and I have made the endocarps for the condenser although there needs zealot of fettling tone done .. I have used the small drill sharpening tool to dill and tap the 60 odd 7BA holes for the bolts and screws ?!!!!
Willy
crueby:
Thats a neat looking assembly! And a lot of holes to drill and tap!
steam guy willy:
--- Quote from: crueby on June 28, 2025, 03:26:52 am ---Thats a neat looking assembly! And a lot of holes to drill and tap!  Thanks and yes there are about 300 nuts and bolts on this engine ???!!!
Willy
--- End quote ---
steam guy willy:
The condenser end plates have all been drilled and tapped 7BA  with no breakages ...!!  i use the resistor colour code to quickly identify my drills and tools etc... so...Purple is the colour for 7 and Green is the colour for 5 ... this is quite helpful unless of course one is colour blind ??!!!   the next job is to install the condenser tubes these are actually soft soldered in place at both ends , rather than expanded as per steel tubes ...
Willy
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
