Author Topic: Prazi SD300 (Hobbymat) vs. Sherline Lathe  (Read 4969 times)
Offline pirmin
Re: Prazi SD300 (Hobbymat) vs. Sherline Lathe
« Reply #75 on: January 11, 2025, 01:55:51 AM »
awesome purchase. just check if there are any zamac /zink parts on your machine and if so check for cracks, older emcos have one problem, called Zinkpest in german. the zamac alloy has impuritys and somehow a internal oxidation letds the parts crumble. from the outside not visible but it is vwery common. emcomat7 and prior machines i often see this issue. but beside that, they are perfect model engineer machines,  i am a emco user myself and love my compact 8
Offline Bear
  • Idaho, USA
« Reply #76 on: January 11, 2025, 02:26:55 AM »
Thanks all. I will post some pictures as requested once it is all done being set up. I will probably just start another thread.
« Reply #77 on: January 11, 2025, 07:18:12 AM »
Not unlike the Emcomat 8.6 I used to have. Luckily never had a problem with the zinc castings or two speed motor switching. The zinc problem is more likely if the machine has been in a damp workshop.
Although the name says V10 there is quite a lot about the 7 & 8 on this group.
https://groups.io/g/emcoV10lathe
Offline Bear
  • Idaho, USA
« Reply #78 on: January 11, 2025, 04:06:47 PM »
Thanks, Jason. Here is a photo I took while cleaning the lathe/mill, before I set it up. I am still in process of setting it up.
