I'm confused, are we looking at two different stops or do these two assemblies work together? It appears that the upper one has a taper on it, does that match the spindle taper?I don't have the book. ThanksDave
Yes, that would work but I think having a guide near chuck is a worthwhile feature, the diameters are quite small when you get below M3 nuts. The droop might make it irritating to feed through the chuck jaws.gerrit
Quote from: gerritv on December 03, 2024, 07:15:42 PMYes, that would work but I think having a guide near chuck is a worthwhile feature, the diameters are quite small when you get below M3 nuts. The droop might make it irritating to feed through the chuck jaws.gerritWhat if the guide was a close it most of the way through the headstock, just went narrow at the chuck end?
