Author Topic: Freelance 3/4” traction engine  (Read 11649 times)
Offline Team ricky
Re: Freelance 3/4” traction engine
« Reply #15 on: December 03, 2024, 02:10:28 PM »
Ah ok …. An incorrect wife’s tale I’ve remembered!
So onto the most sensible approach of dropping the pressure I think….
I would at a guess think that during the pressure test you would get signs of issues as the pressure rises, I.e visible distortion of the flat surfaces and or cracking sounds both of which are a fail even if the boilers in tact it would show it’s been pushed too high !
I can’t think of any real need to go over 40psi WP unless I’m missing something here !?
Online Jasonb
« Reply #16 on: December 03, 2024, 02:40:56 PM »
Offline Team ricky
« Reply #17 on: December 03, 2024, 03:42:57 PM »
That’s a interesting read :)
Thanks for sharing that !
I guess the 80’s were just built different ! Accepting bulging seems a bit wild !
Offline propforward
  • MN, USA
    • Stuart's Shednanigans
« Reply #18 on: December 03, 2024, 05:17:58 PM »
Also, if you're pumping away and the pressure won't go up - that's a problem. Or if the pressure drops during the hold periods. There should not be any pressure drop. Not all failures are accompanied by a sudden sound on pressure vessels. Keep an eye on all your joints for little bubbles coming out. It doesn't always take much of a leak before the pressure suddenly won't hold, even on a great big vessel. I'm more familiar with those than small model ones.
As for bulging it's a question of how much - I think the article mentions "slightly" which is a bit ambiguous. Everything will deflect some amount - it's just how much is allowable. If the material yields that is a problem. But the material can still permanently deform and be sound. I can't tell if the author means for the material to bulge permanently or temporarily (elastically - i.e. goes back where it started when the pressure is relieved). I think I'd prefer that myself, but I am the cautious sort.
So, there I go complicating it again. Interesting though, isn't it?
Stuart - "He Meant Well"
« Reply #19 on: December 03, 2024, 07:12:05 PM »
I can still remember testing my self-made Kupfee boiler with a pressure of 4.8 bar. The normal operating pressure is 3.0 bar. Operating pressure x 1.6 = 4.8.
The copper, which is still soft after soldering, will deform slightly during the pressure test. It should not be visible to the eye.
It could be that the test pressure is calculated differently in each country. For us it is a factor of 1.6.
(If it hasn't changed again)
My copper boiler was an 89mm diameter tube.
Greetings Michael
Online Jasonb
« Reply #20 on: December 03, 2024, 08:13:01 PM »
Usually twice working pressure here.
Best to look for water not bubbles as you should really be hydraulically testing the boiler as should something let go the water inside won't go bang like it would if the boiler was being tested with 150psi of air. Usual trick is to put a small boiler on a paper towel and see if it darkens where it gets wet. Even if using compressed air to provide the pressure for testing the boiler should be filled with water and air only in the eairline and  a bit of pipe work.
You should also be able to isolate the pump so that any drop is not due to leak back through the pump
« Reply #21 on: December 03, 2024, 08:24:39 PM »
What Jason said!  With water filled boiler, any minor seep is visible as drops forming on the outside if tiny, anything larger will throw a visible stream like a squirtgun. Even full size boilers are tested with water.
Offline propforward
  • MN, USA
« Reply #22 on: December 03, 2024, 09:30:28 PM »
Yes - it tends not to go "bang" as badly if something hasn't worked out.  ;D
Offline propforward
  • MN, USA
« Reply #23 on: December 04, 2024, 03:16:02 AM »
Just for the sake of interest - not wanting to go too far off topic - in the states the Boiler and Pressure Vessel code is used to govern just about everything. The hydro test in Section VIII Division I is based on the ratio of material stress at test temperature divided by the material stress at design temperature - all multiplied by 1.3. So not a fixed factor so to speak. That said every model pressure vessel I have seen simply goes to 2.0 X the working pressure, because the actual code requirement lands between 1.5 and 2.0 typically, so 2.0 is easier to remember and adds a bit of safety factor.
The piping codes have a different value. The BPV code also makes allowance for pneumatic testing, and in that case it's the stress ratios multiplied by 1.1.
But again, this is all for interest value only. Everyone needs to go with their local laws and codes and be guided by their local clubs / inspectors.
Offline Team ricky
« Reply #24 on: December 04, 2024, 04:22:12 PM »
Thanks for all the tips chaps ;)
I now know what to look out for !
I have a garden spray pump which I’ll use for the test ….. should get 100psi at its upper limits….
A bit more done today, I drilled the steam ports into the cylinder and machined up the slide valve which turned out very good 😊
Offline Team ricky
« Reply #25 on: April 05, 2025, 06:23:14 PM »
It’s been a while :)
Moved house and just picked up some project work now !
Here’s the boiler close to finished, I did luckily find a better boiler shell and fire box on eBay which im much happier soldering and finishing
I’ve just finished soldering the main areas and leak checked briefly at 60 psi and alls good so far !
Just the blow down bush to solder in and it’s ready to test at full pressure
Offline Team ricky
« Reply #26 on: April 05, 2025, 06:23:54 PM »
Couple more
Offline Team ricky
« Reply #27 on: April 16, 2025, 06:02:54 PM »
A little more done / underway :)
Mainly a mock up as I’m not following the plans for the engine/cylinder side of things
I’m going for a simple achievable engine that runs forward only and I will use the steam regulator to set it going!
The cylinder and trunk , bottom cover are made up, The flywheel is good , the crankshaft material is here now so I will probably make that tomorrow ;)
The mamod wheels are ok not brilliant but will get things going, They will look alot better with decent solid rubber added…
Offline Team ricky
« Reply #28 on: April 17, 2025, 06:48:38 PM »
A small part made today ;)
A slightly reduced cross head taken from the Borderer twin engine plans
Looks great so far and will take a good looking connection rod
The trunk guide I made in cast iron and honed the inside just for practice 😉
Offline Team ricky
« Reply #29 on: April 23, 2025, 11:23:44 PM »
Here’s the crank shaft done ✔️
Simple built up crank with taper pins
